[Qgis-developer] Segmentation fault when using layersRemoved SIGNAL.
Germán Carrillo carrillo.german at gmail.com
Fri Jun 17 15:28:15 PDT 2016
Should I open a ticket reporting this issue to the QGIS issue tracker?
Regards,
Germán
2016-06-13 15:53 GMT-05:00 Germán Carrillo <carrillo.german at gmail.com>:
> Hi All,
> there seems to be an issue connecting the SIGNAL layersRemoved from
> QgsMapLayerRegistry.
> For example, if I save this script to a file, and run it from the Linux
> terminal:
> import unittest
> from qgis.core import QgsApplication, QgsMapLayerRegistry
> class SIGNALTest( unittest.TestCase ):
>     def setUp( self ):
>         app = QgsApplication([], True)
>         QgsApplication.setPrefixPath("/usr", True)
>         QgsApplication.initQgis()
>         QgsMapLayerRegistry.instance().layersRemoved.connect(
> self.myFunction )
>     def myFunction( self, layerIds ):
>         print "Called!"
>     def test1( self ):
>         self.assertEqual(1,1)
>     def tearDown( self ):
>         QgsApplication.exitQgis()
> if __name__ == "__main__":
>     unittest.main()
> I get the following result:
> Called!
> Ran 1 test in 0.119s
> OK
> Segmentation fault
> If, on the contrary, I comment out the line where the connection is set or
> if I use other signals such as layerRemoved or layersAdded instead of
> layersRemoved, I get:
> Ran 1 test in 0.111s
> OK
> I'm using QGIS 2.14.2 on a GNU/Linux machine.
> Can you confirm such problem? Do you have any clue about it?
> Regards,
> Germán
>    |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
> http://twitter.com/GeoTux2
> http://about.me/germancarrillo
> <http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
   |\__
(:>__)(
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160617/81ee5875/attachment.html>
