[Qgis-developer] Segmentation fault when using layersRemoved SIGNAL.
René-Luc Dhont
rldhont at gmail.com
Sat Jun 18 03:56:56 PDT 2016
Open a ticket with your code example.
Regards,
Le 18/06/2016 00:28, Germán Carrillo a écrit :
> Should I open a ticket reporting this issue to the QGIS issue tracker?
> Regards,
> Germán
> 2016-06-13 15:53 GMT-05:00 Germán Carrillo <carrillo.german at gmail.com
> <mailto:carrillo.german at gmail.com>>:
> Hi All,
> there seems to be an issue connecting the SIGNAL layersRemoved
> from QgsMapLayerRegistry.
> For example, if I save this script to a file, and run it from the
> Linux terminal:
> import unittest
> from qgis.core import QgsApplication, QgsMapLayerRegistry
> class SIGNALTest( unittest.TestCase ):
> def setUp( self ):
> app = QgsApplication([], True)
> QgsApplication.setPrefixPath("/usr", True)
> QgsApplication.initQgis()
> QgsMapLayerRegistry.instance().layersRemoved.connect(
> self.myFunction )
> def myFunction( self, layerIds ):
> print "Called!"
> def test1( self ):
> self.assertEqual(1,1)
> def tearDown( self ):
> QgsApplication.exitQgis()
> if __name__ == "__main__":
> unittest.main()
> I get the following result:
> Called!
> Ran 1 test in 0.119s
> OK
> Segmentation fault
> If, on the contrary, I comment out the line where the connection
> is set or if I use other signals such as layerRemoved or
> layersAdded instead of layersRemoved, I get:
> Ran 1 test in 0.111s
> OK
> I'm using QGIS 2.14.2 on a GNU/Linux machine.
> Can you confirm such problem? Do you have any clue about it?
> Regards,
> Germán
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
> http://twitter.com/GeoTux2
> http://about.me/germancarrillo
> <http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
> |\__
> (:>__)(
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160618/26a50aea/attachment.html>
