[Qgis-developer] Segmentation fault when using layersRemoved SIGNAL.
Germán Carrillo
carrillo.german at gmail.com
Mon Jun 20 08:54:38 PDT 2016
For reference, this is the ticket I've just opened:
http://hub.qgis.org/issues/15088
Regards,
Germán
2016-06-18 5:56 GMT-05:00 René-Luc Dhont <rldhont at gmail.com>:
> Open a ticket with your code example.
> Regards,
> Le 18/06/2016 00:28, Germán Carrillo a écrit :
> Should I open a ticket reporting this issue to the QGIS issue tracker?
> Regards,
> Germán
> 2016-06-13 15:53 GMT-05:00 Germán Carrillo <carrillo.german at gmail.com>:
>> Hi All,
>> there seems to be an issue connecting the SIGNAL layersRemoved from
>> QgsMapLayerRegistry.
>> For example, if I save this script to a file, and run it from the Linux
>> terminal:
>> import unittest
>> from qgis.core import QgsApplication, QgsMapLayerRegistry
>> class SIGNALTest( unittest.TestCase ):
>> def setUp( self ):
>> app = QgsApplication([], True)
>> QgsApplication.setPrefixPath("/usr", True)
>> QgsApplication.initQgis()
>> QgsMapLayerRegistry.instance().layersRemoved.connect(
>> self.myFunction )
>> def myFunction( self, layerIds ):
>> print "Called!"
>> def test1( self ):
>> self.assertEqual(1,1)
>> def tearDown( self ):
>> QgsApplication.exitQgis()
>> if __name__ == "__main__":
>> unittest.main()
>> I get the following result:
>> Called!
>> Ran 1 test in 0.119s
>> OK
>> Segmentation fault
>> If, on the contrary, I comment out the line where the connection is set
>> or if I use other signals such as layerRemoved or layersAdded instead of
>> layersRemoved, I get:
>> Ran 1 test in 0.111s
>> OK
>> I'm using QGIS 2.14.2 on a GNU/Linux machine.
>> Can you confirm such problem? Do you have any clue about it?
>> Regards,
>> Germán
>> |\__
>> (:>__)(
>> Soluciones Geoinformáticas Libres
>> http://geotux.tuxfamily.org/
>> http://twitter.com/GeoTux2
>> http://about.me/germancarrillo
>> <http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
> |\__
> (:>__)(
> Qgis-developer mailing listQgis-developer at lists.osgeo.org
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
|\__
(:>__)(
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160620/36422957/attachment.html>
