[Qgis-developer] Any plans for implementing vector tile generation on QGIS Server?
René-Luc Dhont
rldhont at gmail.com
Mon Jun 20 09:24:47 PDT 2016
I have some code to build a vector tile based on qgsVectorLayer but I
have not yet time to build a QGIS Server Plugin to use it. I'll be
pleased to do it.
Regards,
René-Luc
Le 19/06/2016 02:36, Thomas Gratier a écrit :
> Hi,
> Although it will not change the issue to support vector tiles in QGIS
> Server, TileStache does support PBF. It's just that you need the
> forked version from Mapzen e.g
> https://github.com/mapzen/TileStache/blob/integration-1/TileStache/Goodies/VecTiles/mvt.py
> Cheers
> Thomas Gratier
> 2016-06-19 1:51 GMT+02:00 Nikolai Bezdna <mofoyoda at gmail.com
> <mailto:mofoyoda at gmail.com>>:
> Hi Marco,
> As far as I know vector tiles can’t be generated out of WMS
> services, because WMS spec is mostly used for getting raster
> images (GetMap request) or feature information (GetFeatureInfo
> request) and some others.
> I guess you meant WFS really, but I don’t know any caching server
> implementations that use WFS as a background and generate vector
> tiled PBFs (particularly in Mapbox Vector Tiles spec
> <https://github.com/mapbox/vector-tile-spec>).
> I didn’t use MapServer MapCache
> <http://www.mapserver.org/mapcache/>, but according to the docs
> it doesn’t support vector tiles, only raster ones. MapProxy and
> TileCache don’t support them either. TileStache can produce vector
> tiles out of OGR datasource, but in GeoJSON format, which is way
> heavier than PBF, even gzipped.
> So the good way to go would be to use the OGR MVT driver, but
> unfortunately it’s not released and the status of it’s development
> is unknown. While web is moving fast towards in-browser rendering
> (OpenLayers3 and Mapbox GL already utilise WebGL for that) it’s
> becoming clear QGIS server should support vector tiles at some
> point. Should I start with a feature request maybe?
> Regards,
> Nick
> From: Marco Hugentobler <marco.hugentobler at sourcepole.ch
> <mailto:marco.hugentobler at sourcepole.ch>>
> To: qgis-developer at lists.osgeo.org
> <mailto:qgis-developer at lists.osgeo.org>
> Subject: Re: [Qgis-developer] Any plans for implementing vector tile
> Message-ID: <5765066C.3000905 at sourcepole.ch
> <mailto:5765066C.3000905 at sourcepole.ch>>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> Hi Nikolai
> Most vector tile generators can work with any WMS in the background.
> E.g. using MapCache with QGIS server should be perfectly possible.
> Regards,
> Marco
> On 06/18/16 10:13, Nikolai Bezdna wrote:
>> I’d like to know if there are any plans for enabling serving vector
>> tiles from QGIS Server, so they can be used in client libraries like
>> Mapbox GL afterwards. Seems like GDAL (OGR really) MVT driver is
>> stuck
>> in development and there already are some stand-alone
>> implementations,
>> like utilery (https://github.com/tilery/utilery) or Mapnik vector
>> tile
>> (https://github.com/mapbox/mapnik-vector-tile), but nothing is
>> integrated with QGIS server. Since Mapbox and ESRI adopted MVT, and
>> most major web basemaps (like Google, Apple etc.) are already vector
>> tile based, it seems like QGIS is running a bit behind in this
>> field.
>> So it would be great to start a discussion on utilising vector tile
>> spec within QGIS.
>> Cheers
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160620/02ef0f1b/attachment.html>
