[Qgis-developer] Problem definig snapping options programmatically
EFTAS Christian Röttger
Christian.Roettger at eftas.com
Thu Jun 23 06:38:58 PDT 2016
Hi developers,
i'm facing a problem which i do not understand. In our plugin I created a function to set snapping options and bound it to a shortcut.
Using Qgis 2.14.3, source code see below.
The assigned shortcut works well, but for the snapping I have to do the following on every QGIS start:
Go to snapping options, mode = advanced, press ok (without changing anything). Then it works afterwards!
But when I print the options before I do this, I definitely get the right options (see below).
Does anyone know what I'm missing? Should I open an bug report? Is there a workaround do do: "Go to snapping options, mode = advanced, press ok" programmatically ?
Thanks for any help
Christian
## Print result
Initialize, when aggroInstance is true
(True, False, 2, 0, 2.0, True)
checked
(True, True, 2, 0, 2.0, False)
## function
def toggleSnapping(checked):
Toggle snapping option
:param checked: True if snapping has been activated, False otherwise
aggroInstance = initModule.aggroInstance
print 'Initialize'
if bool(agroInstance):
for item in QgsMapLayerRegistry.instance().mapLayers().values():
QgsProject.instance().setSnapSettingsForLayer(item.id(), False, 2, 0, 2, True)
fieldLayer = mapUtils.getLayerByName(aggroInstance.dictData['field'])
backgroundLayer = mapUtils.getLayerByName('bg')
print QgsProject.instance().snapSettingsForLayer(item.id())
if checked:
print 'checked'
# Convenience function to set snap settings per layer.
# it defines the snapping options:
# id : the id of your layer, True : to enable the layer snapping, 2 : options (2: vertex+segment), 0: type of unit on map, 2 : tolerance, true : avoidIntersection)
QgsProject.instance().setSnapSettingsForLayer(fieldLayer.id(), True, 2, 0, 2, False)
QgsProject.instance().setSnapSettingsForLayer(backgroundLayer.id(), True, 2, 0, 2, False)
## initialization in run() method
# Call Snapping Tool by a key shortcut
for action in self.actions:
if action.text() == 'Toggle Snapping':
# Action triggered by shortcut key
self.iface.registerMainWindowAction(action, "c")
[eftas3]
Dipl.-Geoinf. Christian Röttger
-Forschung und Entwicklung
E F T A S Fernerkundung
Technologietransfer GmbH
Oststraße 2-18
48145 Münster
Fon: +49 251 13307-23 E-Mail: christian.roettger at eftas.com<mailto:christian.roettger at eftas.com>
Fax: +49 251 13307-33 Web: http://www.eftas.com<http://www.eftas.com/>
Geschäftsführer:
Dipl.-Ing. Georg Altrogge
Sitz der Gesellschaft: Münster
Amtsgericht Münster, HRB 2999
USt.-IdNr. DE 126038986
[image007]
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160623/ee5188af/attachment-0001.html>
Type: image/gif
Desc: image001.gif
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160623/ee5188af/attachment-0003.gif>
Type: image/gif
Desc: image002.gif
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160623/ee5188af/attachment-0004.gif>
Type: image/gif
Desc: image003.gif
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160623/ee5188af/attachment-0005.gif>
