[Qgis-developer] Problem definig snapping options programmatically
Matthias Kuhn
matthias at opengis.ch
Thu Jun 23 06:55:33 PDT 2016
Hi Christian,
Does it help if you call
QgsProject.instance().snapSettingsChanged()
Cheers
Matthias
On 06/23/2016 03:38 PM, EFTAS Christian Röttger wrote:
> Hi developers,
> i’m facing a problem which i do not understand. In our plugin I created
> a function to set snapping options and bound it to a shortcut.
> Using Qgis 2.14.3, source code see below.
> The assigned shortcut works well, but for the snapping I have to do the
> following on every QGIS start:
> Go to snapping options, mode = advanced, press ok (without changing
> anything). Then it works afterwards!
> But when I print the options *before* I do this, I definitely get the
> right options (see below).
> Does anyone know what I’m missing? Should I open an bug report? Is there
> a workaround do do: “Go to snapping options, mode = advanced, press ok”
> programmatically ?
> Thanks for any help
> Christian
> ## Print result
> Initialize, when aggroInstance is true
> (True, False, 2, 0, 2.0, True)
> checked
> (True, True, 2, 0, 2.0, False)
> ## function
> *def *toggleSnapping(checked):
> Toggle snapping option
> /*:param*/checked: True if snapping has been activated, False otherwise
> /aggroInstance = initModule.aggroInstance
> *print **'Initialize'
> **if *bool(agroInstance):
> *for *item *in *QgsMapLayerRegistry.instance().mapLayers().values():
> QgsProject.instance().setSnapSettingsForLayer(item.id(),
> False, 2, 0, 2, True)
> fieldLayer =
> mapUtils.getLayerByName(aggroInstance.dictData[*'field'*])
> backgroundLayer = mapUtils.getLayerByName(*'bg'*)
> *print *QgsProject.instance().snapSettingsForLayer(item.id())
> *if *checked:
> *print **'checked'
> */# Convenience function to set snap settings per layer.
> # it defines the snapping options:
> # id : the id of your layer, True : to enable the layer
> snapping, 2 : options (2: vertex+segment), 0: type of unit on map, 2 :
> tolerance, true : avoidIntersection)
> /QgsProject.instance().setSnapSettingsForLayer(fieldLayer.id(), True, 2,
> 0, 2, False)
> QgsProject.instance().setSnapSettingsForLayer(backgroundLayer.id(),
> True, 2, 0, 2, False)
> *for *item *in
> *print
> ## initialization in run() method
> /# Call Snapping Tool by a key shortcut
> /*for *action *in *self.actions:
> *if *action.text() == *'Toggle Snapping'*:
> /# Action triggered by shortcut key
> /self.iface.registerMainWindowAction(action, *"c"*)
> image003
> eftas3
> Dipl.-Geoinf. Christian Röttger
> -Forschung und Entwicklung
> E F T A S Fernerkundung
> Technologietransfer GmbH
> Oststraße 2-18
> 48145 Münster
> Fon: +49 251 13307-23 E-Mail: christian.roettger at eftas.com
> <mailto:christian.roettger at eftas.com>
> Fax: +49 251 13307-33 Web: http://www.eftas.com
> <http://www.eftas.com/>
> Geschäftsführer:
> Dipl.-Ing. Georg Altrogge
> Sitz der Gesellschaft: Münster
> Amtsgericht Münster, HRB 2999
> USt.-IdNr. DE 126038986
> image007
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
