[Qgis-developer] build q-gis gti_master from source on debian 8
christoph
christoph.macho at gmx.at
Mon Jun 27 07:49:42 PDT 2016
Hello everyone,
I try to build QGIS-master from source on my debian 8 system
with self compiled versions of:
gdal 2.2.0
liblas 1.8.0
grass 7.04.
proj 4.9.2
geos 3.5.0
spatiliteindex 1.8.4
libspatialite 4.3.0a
netcdf-4-4.0
wxWidges3.1.0
cmake 3.5.2
qwt-6.1
qwt-polar 1.1.1
debian:
qt 4.8.6
python 2.7
see here:
-- QGIS version: 2.15.0 Master (21500)
-- Could not find GRASS 6
-- Found GRASS 7: /usr/lib/grass (7.0.4, off_t size = )
-- Found Proj: /usr/local/lib/libproj.so
-- Found GEOS: /usr/local/lib/libgeos_c.so (3.5.0)
-- Found GDAL: /usr/local/lib/libgdal.so (2.2.0dev)
-- Found Expat: /usr/lib/x86_64-linux-gnu/libexpat.so
-- Found Spatialindex: /usr/local/lib/libspatialindex.so
-- Found Qwt: /usr/local/lib/libqwt.so (6.1.4)
-- Found Sqlite3: /usr/lib/x86_64-linux-gnu/libsqlite3.so
-- Found PostgreSQL: /usr/lib/x86_64-linux-gnu/libpq.so
-- Found SpatiaLite: /usr/local/lib/libspatialite.so
-- Qt WebKit support enabled
-- Found Qt version: 4.8.6
-- Touch support disabled
-- Found QScintilla2: /usr/lib/libqscintilla2.so (2.8.4)
-- Found QCA: /usr/lib/x86_64-linux-gnu/libqca.so (2.0.3)
-- QCA OpenSSL plugin C++ check failed to compile
-- QCA OpenSSL plugin C++ check compile output:
-- Change Dir: /home/christoph/myworld/QGIS/cmake_qgis/CMakeFiles/CMakeTmp
Compilation runs fine without any trouble,
but nearly all test fail,
and when I try to start :
christoph at excelsior:~/ qgis
Speicherzugriffsfehler
why this ?
