[Qgis-developer] custom charts?
Raymond Nijssen
r.nijssen at terglobo.nl
Tue Jun 28 07:31:27 PDT 2016
Here is an example of a map with code generated svg images as symbols.
The quick and dirty script does:
- aggregate all features from input point layer with same geometry
- calculate min/max times and values for whole set
- create svg files for every feature with filename based on id
- create a layer in qgis
Manually i added the data defined filename based on the id:
'/tmp/img_measure_' || "imgid" || '.svg'
Et voila!
http://terglobo.nl/downloads/voorbeeld_kaart_01.png
Thank you all for your suggestions!
Raymond
On 26-06-16 11:58, Raymond Nijssen wrote:
> There is this library to make it easier:
> https://pypi.python.org/pypi/svgwrite/
> And since it is python, you can use the standard code editor in QGIS (or
> an external one if you prefer).
> Raymond
> On 25-06-16 21:33, Lauri Kajan wrote:
>> This would be great also for nautical charts to render light sectors
>> from S57 data.
>> Could existing code editor be used to construct the svg with some python
>> svg library?
>> -Lauri
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Terglobo
Fahrenheitstraat 1
5223 BJ 's-Hertogenbosch
06 25 31 49 83
