[Qgis-developer] custom charts?
Marco Bernasocchi
marco at opengis.ch
Tue Jun 28 13:16:44 PDT 2016
Nice workflow!
On 29 June 2016 02:31:27 GMT+12:00, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
>Here is an example of a map with code generated svg images as symbols.
>The quick and dirty script does:
>- aggregate all features from input point layer with same geometry
>- calculate min/max times and values for whole set
>- create svg files for every feature with filename based on id
>- create a layer in qgis
>Manually i added the data defined filename based on the id:
>'/tmp/img_measure_' || "imgid" || '.svg'
>Et voila!
>http://terglobo.nl/downloads/voorbeeld_kaart_01.png
>Thank you all for your suggestions!
>Raymond
>On 26-06-16 11:58, Raymond Nijssen wrote:
>> There is this library to make it easier:
>> https://pypi.python.org/pypi/svgwrite/
>> And since it is python, you can use the standard code editor in QGIS
>(or
>> an external one if you prefer).
>> Raymond
>> On 25-06-16 21:33, Lauri Kajan wrote:
>>> This would be great also for nautical charts to render light sectors
>>> from S57 data.
>>> Could existing code editor be used to construct the svg with some
>python
>>> svg library?
>>> -Lauri
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>Terglobo
>Fahrenheitstraat 1
>5223 BJ 's-Hertogenbosch
>06 25 31 49 83
Marco Bernasocchi (mobile).
OPENGIS.ch - berna.io - 27summits.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160629/81b9f710/attachment-0001.html>
