[Qgis-developer] Shape repack issue
Neumann, Andreas a.neumann at carto.net
Wed Jun 29 07:44:59 PDT 2016
Hi Even,
Thank you for your thorough review of the situation and the explanation.
I asked the person who reopened this bug to provide more details - which
we hopefully get. Otherwise, I suggest we close this issue again.
Andreas
On 2016-06-29 15:45, Even Rouault wrote:
> Andreas,
> I cannot confirm. But the bug has been reopened without specifying the
> operating system, the GDAL version and the exact procedure followed (possibly
> with the dataset in case it might make a difference), so it might hit some
> particular case.
> So here's my setup :
> - versions tried : up-to-date versions of QGIS master and 2.14 branch
> - OS: Linux
> - GDAL >= 2.1
> Steps :
> 1) Download:
> http://svn.osgeo.org/gdal/trunk/autotest/ogr/data/poly.shp
> http://svn.osgeo.org/gdal/trunk/autotest/ogr/data/poly.shx
> http://svn.osgeo.org/gdal/trunk/autotest/ogr/data/poly.dbf
> 2) Open the shapefile in QGIS
> 3) Turn on edition mode
> 4) Select the feature with EAS_ID = 165 (the one roughly at the middle)
> 5) Delete it
> 6) Turn off edition mode and confirm saving the changes
> 7) Quit QGIS and do "ogrinfo -al poly.shp". You'll see "Feature Count: 9" and
> 9 features numeroted without hole from OGRFeature(poly):0 to
> OGRFeature(poly):8
> Sure, a test could be added to simulate that (looking at
> test_provider_shapefile.py it doesn't seem there's one), but there's probably
> something we miss here w.r.t. the reporter setup.
> On the reverse, to see the effect of *no* repacking, if you do :
> 1) Download:
> 2) ogrinfo poly.shp -sql "delete from poly where eas_id = 165" -dialect sqlite
> 3) ogrinfo -al poly.shp. You'll see "Feature Count: 10" and features numbered
> from  OGRFeature(poly):0 to OGRFeature(poly):9 with a hole (OGRFeature(poly):8
> missing) --> the shapefile hasn't been repacked (as "expected" from current OGR
> behaviour)
> Even
>> Hi,
>> There is (hopefully was) this annoying ESRI Shape Repack issue - see
>> http://hub.qgis.org/issues/11007
>> I see that this bug was re-opened - Antoine SIG claims that it worked in
>> 2.14.1 and 2.14.2 (Windows) but fails again in 2.14.3. Can someone
>> confirm? How can that happen? Can a test be added to ensure this doesn't
>> fail again?
>> How about 2.16? Does it work there if it is built with GDAL 2.x?
>> I can't reproduce, since I don't have another GIS besides QGIS to check.
>> Thanks,
>> Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160629/4c306243/attachment.html>
