[Qgis-developer] Lots of SVG images not visible in composers add image
Nyall Dawson
nyall.dawson at gmail.com
Sun Mar 6 20:46:39 PST 2016
On 6 March 2016 at 06:14, Alexandre Neto <senhor.neto at gmail.com> wrote:
> As a workaround fix before the implementation of that feature, could we add
> some default values to the transparency values, as it was done with the
> colors?
Here's a PR which fixes it:
https://github.com/qgis/QGIS/pull/2876
But it's also a feature, so not sure if it's suitable for backporting
to 2.14. In any case extensive testing would be very much appreciated!
Nyall
> At the QGIS PT user group, I provide the old SVG files for people to use in
> the meanwhile.
> https://dl.dropboxusercontent.com/u/5088211/svg.zip
> Alexandre Neto
> A sáb, 5/03/2016, 04:03, Nyall Dawson <nyall.dawson at gmail.com> escreveu:
>> On 4 Mar 2016 23:45, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
>> > Hello all,
>> > There are lots of SVG files that do not seem to not render in the Print
>> > Composer, and they are not visible in the display section of the items
>> > properties.
>> > Anyone confirm this?
>> > https://dl.dropboxusercontent.com/u/5088211/Screenshot%20from%202016-03-04%2012%3A42%3A56.png
>> I've had a look at this, and it was actually a really old commit which
>> caused it (12 Oct last year)... Strange that no one's picked this up before
>> now!
>> The fix will be for someone to implement http://hub.qgis.org/issues/13326,
>> and then get permission to backport this feature as a fix to 2.14.
>> Nyall
>> > Cheers
>> > Alexandre Neto
>> > Alexandre Neto
>> > @AlexNetoGeo
>> > http://sigsemgrilhetas.wordpress.com
>> > http://gisunchained.wordpress.com
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexandre Neto
> @AlexNetoGeo
