[Qgis-developer] Lots of SVG images not visible in composers add image
Nyall Dawson
nyall.dawson at gmail.com
Sun Mar 6 20:48:21 PST 2016
On 7 March 2016 at 15:46, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 6 March 2016 at 06:14, Alexandre Neto <senhor.neto at gmail.com> wrote:
>> As a workaround fix before the implementation of that feature, could we add
>> some default values to the transparency values, as it was done with the
>> colors?
> Here's a PR which fixes it:
> https://github.com/qgis/QGIS/pull/2876
> But it's also a feature, so not sure if it's suitable for backporting
> to 2.14. In any case extensive testing would be very much appreciated!
One last thing... since this switches the composer picture to use the
SVG cache for rendering svg files, it opens the composer up to
http://hub.qgis.org/issues/13565. I'm not sure if that's an issue or
not.
Feedback welcome!
Nyall
> Nyall
>> At the QGIS PT user group, I provide the old SVG files for people to use in
>> the meanwhile.
>> https://dl.dropboxusercontent.com/u/5088211/svg.zip
>> Alexandre Neto
>> A sáb, 5/03/2016, 04:03, Nyall Dawson <nyall.dawson at gmail.com> escreveu:
>>> On 4 Mar 2016 23:45, "Alexandre Neto" <senhor.neto at gmail.com> wrote:
>>> > Hello all,
>>> > There are lots of SVG files that do not seem to not render in the Print
>>> > Composer, and they are not visible in the display section of the items
>>> > properties.
>>> > Anyone confirm this?
>>> > https://dl.dropboxusercontent.com/u/5088211/Screenshot%20from%202016-03-04%2012%3A42%3A56.png
>>> I've had a look at this, and it was actually a really old commit which
>>> caused it (12 Oct last year)... Strange that no one's picked this up before
>>> now!
>>> The fix will be for someone to implement http://hub.qgis.org/issues/13326,
>>> and then get permission to backport this feature as a fix to 2.14.
>>> Nyall
>>> > Cheers
>>> > Alexandre Neto
>>> > Alexandre Neto
>>> > @AlexNetoGeo
>>> > http://sigsemgrilhetas.wordpress.com
>>> > http://gisunchained.wordpress.com
>>> > _______________________________________________
>>> > Qgis-developer mailing list
>>> > Qgis-developer at lists.osgeo.org
>>> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alexandre Neto
>> @AlexNetoGeo
