[Qgis-developer] share plugins (English required)
DelazJ
delazj at gmail.com
Fri Mar 11 07:06:25 PST 2016
Martin, note that few hours ago (
http://osgeo-org.1560.x6.nabble.com/plugin-translation-td5255634.html),
Matteo Ghetta has committed in QGIS-Doc repository a description of steps
to have a plugin translated.
It should be available at
http://docs.qgis.org/testing/en/docs/pyqgis_developer_cookbook/plugins.html
tomorrow. It may be of help for your team to get the plugin translated more
easily. (Feedbacks are welcome)
Regards,
DelazJ
2016-03-11 16:03 GMT+01:00 Richard Duivenvoorde <rdmailings at duif.net>:
> On 11-03-16 15:27, Neumann, Andreas wrote:
> > Hi Martin,
> > This may be a good case where you can set up your own local plugin
> > repository.
> > Maybe there is a Czech FOSSGIS user group that can host it.
> > Hosting a QGIS plugin repository only requires a webserver with an XML
> > file and the plugins as zip files. It is really simple to set up.
> > And it is very simple to add an additional repository to the QGIS plugin
> > repository. Just add the URL and your done.
> > Many larger organizations have their own in-house plugin repositories.
> @martin, if you want, I have examples of those.
> But in general I think it would still be good to stick to the plan: a
> big international repo, which every body can find, which can be used to
> find examples and example code etc.
> And preferably(!) english/multilingual ( and code/tags/description ), so
> Paolo keep pushing, but please keep the plugins coming (even in
> chinese/persian) :-)
> Maybe a feature for the plugin repo: languages used, so you can filter
> on it?
> Regards,
> Richard
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160311/91cd4c0b/attachment.html>
