[Qgis-developer] QGIS on Windows: order another desktop to accommodate all the icons
    Martin Landa
    landa.martin at gmail.com
    Fri Mar 11 14:19:46 PST 2016
2016-03-11 2:39 GMT+01:00 Jürgen E. <jef at norbit.de>:
> That because we repackage OSGeo4W packages for the standalone installer and
> their postinstall scripts install the icons.  So you also get icons for GRASS
> and SAGA for instance.  Not sure if that's bad.
beside SAGA and GRASS the QGIS alone will create 4(!) different icons.
So 4 (QGIS) + 1 (SAGA) + 1 (GRASS).
>> BTW, uninstall procedure do not remove these icons from desktop.
> That might be because the packages' preremove scripts don't remove the icons in
> OSGeo4W either.
I wanted to say, none of QGIS icons (also SAGA) is removed from
desktop after uninstalling QGIS. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
