[Qgis-developer] qt5 python3 build?
Tim Sutton tim at kartoza.com
Sun Mar 20 02:09:43 PDT 2016
Hi
> On 19 Mar 2016, at 23:54, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> Hi Devs,
> I see a lot of qt5/py3 related commits passing, nice work, thanks.
> Knowing Tim has some build/run dockers for different QGIS versions [0]:
> I think it would be nice to have a docker build for qt5/py3 too. That
> (at least for me) would make it easier to test in parallel with other
> versions (and other distro version).
> So my question: if I want to build in a Debian Jessie Docker, are there
> any extra instructions or packages needed? I see in the Travis yaml
> soemthing about an environment var: QT_VERSION=5
> But we probably also need other libs too?
> Or am I too eager and is it just too early to try this out yet…
I think I will probably get a master build against Qt5 in docker over the next couple of weeks (probably not this week as I am on holiday for the week). If someone wants to make a patch it will be most welcome. Also if there is interest, I can move my git repo referenced below to an official QGIS repo. My biggest problem, at the moment is that docker auto builds are not working as it always times out fetching packages. I’d like to have auto builds for all recent versions so that you can use the containers in production.
QGIS Desktop is mainly interesting for testing on your desktop, but there are also some other interesting use cases:
* Providing a sandboxed build on a network server with all packages etc then making it available to thin clients.
* QGIS Desktop is used directly by the QGIS Server docker recipe - which makes it really really easy to spin up a QGIS server instance on a server.
Regards
Tim
> Regards,
> Richard
> ps: anybody running a decent Linux and has Docker running. Try out the
> docker build/run scripts from [0] :-)
> [0] https://github.com/kartoza/docker-qgis-desktop
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
* Desktop GIS programming services
* Geospatial web development
* GIS Training
* Consulting Services
Skype: timlinux Irc: timlinux on #qgis at freenode.net
Tim is a member of the QGIS Project Steering Committee
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160320/72c2696f/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160320/72c2696f/attachment.png>
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160320/72c2696f/attachment.sig>
