[Qgis-developer] plugin translation
Matthias Kuhn matthias at opengis.ch
Wed Mar 23 00:59:12 PDT 2016
Hi Matteo
On 03/23/2016 08:52 AM, matteo wrote:
> Hi Richard,
>> this Makefile also comes from the plugin builder:
>> https://github.com/rduivenvoorde/sectorplot/blob/master/SectorPlot/Makefile#L183
> weird that I don't have any makefile there.. but that's sure not plugin
> builder fault..
>> In that line it points to scripts (also from the builder plugin):
>> https://github.com/rduivenvoorde/sectorplot/blob/master/SectorPlot/scripts/update-strings.sh
>> which I used to update the strings. I realize these are all shell
>> scripts indeed, but you can use them to find the logic used to do all stuff.
> oh, tough stuff (for me) ;)
> anyway, I see that in the update-strings.sh script, at the end, it has
> been used the command *pylupdate4* and not *lupdate*.. and that was
> exactly the problem I have reported (lupdate does not take the tr()
> function into account)..
> as I said, the only annoying thing I have to do is to write manually all
> the UI files in the .pro one.. but that's not a problem at all..
Maybe that's what you need?
http://sergey.vlasov.me/2013/03/expanding-wildcards-with-qmake.html
Matthias
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
