[Qgis-developer] timemanager plugin + show feature count
Anita Graser
anitagraser at gmx.at
Mon May 2 08:28:57 PDT 2016
On May 2, 2016 4:42 PM, "Richard Duivenvoorde" <rdmailings at duif.net> wrote:
> When using Timemanager plugin on a layer with the right time settings,
> it nicely updates the 'feature count' in the layer manager (as a
> 'filtered' layer).
> But when stepping using the time slider I noted that the feature count
> is only updated when I hover out of the timemanager panel, or into the
> layerlist panel...
> Should I consider this an issue and create an issue for it.
> And if so, is this to be considered a plugin or a qgis issue?
That's a good question. You can certainly create a ticket on the plugin's
tracker. I've no idea how to fix the issue yet though.
Best wishes
Anita
> Regards,
> Richard
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160502/69ba59fc/attachment.html>
