[Qgis-developer] PK not interpreted in 2.14?
Jürgen E. Fischer
jef at norbit.de
Thu May 5 07:08:31 PDT 2016
Hi Paolo,
On Thu, 05. May 2016 at 14:50:33 +0200, Paolo Cavallini wrote:
> postgis tables and views without an unique id are not readable by qgis
> 2.14. The same load fine in 2.8. As a consequence, projects including
> them are broken. Any reasonable solution?
Do you have an example table that works in 2.8 and does in 2.14?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160505/d197a25a/attachment.sig>
