[Qgis-developer] PK not interpreted in 2.14?
Paolo Cavallini
cavallini at faunalia.it
Thu May 5 07:34:02 PDT 2016
Il 05/05/2016 16:08, Jürgen E. Fischer ha scritto:
> Hi Paolo,
> On Thu, 05. May 2016 at 14:50:33 +0200, Paolo Cavallini wrote:
>> postgis tables and views without an unique id are not readable by qgis
>> 2.14. The same load fine in 2.8. As a consequence, projects including
>> them are broken. Any reasonable solution?
> Do you have an example table that works in 2.8 and does in 2.14?
e.g. this
SELECT a.id, a.geom, b.inizio
FROM tab1 a, tab2 b;
where the id is not unique.
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
