[Qgis-developer] closestSegmentWithContext
Worth Lutz wal3 at mindspring.com
Thu May 5 09:25:21 PDT 2016
I'm trying to use "closestSegmentWithContext" method of QgsGeometry in a
plugin. I don't seem to be getting what I'm expecting.
Comparing
http://qgis.org/api/classQgsGeometry.html#ac09505a6a8a29f244a37c6f336cd98e7
with the following from:
https://github.com/qgis/QGIS/blob/master/python/core/geometry/qgsgeometry.sip
      * Searches for the closest segment of geometry to the given point
      * @param point Specifies the point for search
      * @param minDistPoint Receives the nearest point on the segment
      * @param afterVertex Receives index of the vertex after the
closest segment. The vertex
      * before the closest segment is always afterVertex - 1
      * @param leftOf Out: Returns if the point lies on the left of
right side of the segment ( < 0 means left, > 0 means right )
      * @param epsilon epsilon for segment snapping (added in 1.8)
      * @return The squared cartesian distance is also returned in
sqrDist, negative number on error
     double closestSegmentWithContext( const QgsPoint& point, QgsPoint&
minDistPoint /Out/, int& afterVertex /Out/ ) const;
When I try:
    results =
    self.selectedStreetSegment.geometry().closestSegmentWithContext(point)
I get a results as:
    (2560.365846544, (2106395, 746610), 1)
I take this to be (sqrDist, minDistPoint, afterVertex ).  It does not
seem to be returning "leftOf" which is the value I'm looking for.
Is something missing in that "sip" definition?  I do not know what I'm
looking at so I may be looking at the wrong thing. In any case, I cannot
seem to find the results I need.
Thanks,
*Worth Lutz*
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160505/212f6f2a/attachment.html>
