[Qgis-developer] Memory leak in QGIS 2.14 with a Shapefile
Matthias Kuhn
matthias at opengis.ch
Mon May 9 05:59:33 PDT 2016
Have you tested with either the latest 2.14 nightly or master nightly?
An issue with OGR connection pooling has been resolved recently. And I
wonder if that could be related.
-- Matthias
On 05/09/2016 02:28 PM, kimaidou wrote:
> I created an issue about it : http://hub.qgis.org/issues/14792
> 2016-05-09 11:48 GMT+02:00 kimaidou <kimaidou at gmail.com
> <mailto:kimaidou at gmail.com>>:
> Hi again,
> I also forgot to mention that I have no memory leak when using the
> same dataset in PostGIS ( tested by importing the Shapefile in
> PostGIS with shape2pgsql )
> Michaël
> 2016-05-09 11:07 GMT+02:00 kimaidou <kimaidou at gmail.com
> I forgot to mention the steps to reproduce the bug, and the
> precautions to take :
> * open the project in QGIS 2.14 ( I have not tested with older
> versions)
> * open a terminal and use this kind of command to monitor QGIS
> memory consumption : htop, or ps with
> watch -n1 'ps -aux --sort -pmem | head -5'
> * Navigate through the project by zooming in and out, pan,
> etc. I think you emphasize the memory leak by displaying the
> layer at small scale ( with many buildings displayed)
> * Be aware that this will increase the memory, so keep an eye
> on the memory consumption so that your system has enough free
> memory to work properly.
> Michaël
> 2016-05-09 11:00 GMT+02:00 kimaidou <kimaidou at gmail.com
> Hi devs,
> I have just found a memory leak in QGIS Desktop (and
> server) with the project available in [1] ( a 20Mo tar.bz2 )
> This is a very simple project with only one buildings
> Shapefile ( SHP 68Mo). This layer has been exported from
> PostGIS from a query wich aimed to simplify the building
> for fast rendering.
> The geometries have been simplified ( I used SnapToGrid,
> then (St_Dump(St_Union(a.geom))) to remove as many nodes
> as possible )
> The layers has ~ 700 000 features.
> Has anyone encoutered such a leak ?
> [1]
> https://framadrop.org/r/_7VsZtvzdU#+eJHHPPOIdVcgj/AUp8V91T9m6gmO7/XCh6uOhzP7ro=
> Cheers,
> Michaël
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160509/f00f332d/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160509/f00f332d/attachment.sig>
