[Qgis-developer] Memory leak in QGIS 2.14 with a Shapefile
kimaidou
kimaidou at gmail.com
Mon May 9 06:02:32 PDT 2016
Hi Matthias,
Not yet, I need to build QGIS master before being able to report back
Thanks for your answer
2016-05-09 14:59 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
> Have you tested with either the latest 2.14 nightly or master nightly?
> An issue with OGR connection pooling has been resolved recently. And I
> wonder if that could be related.
> -- Matthias
> On 05/09/2016 02:28 PM, kimaidou wrote:
> I created an issue about it : <http://hub.qgis.org/issues/14792>
> 2016-05-09 11:48 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>> Hi again,
>> I also forgot to mention that I have no memory leak when using the same
>> dataset in PostGIS ( tested by importing the Shapefile in PostGIS with
>> shape2pgsql )
>> Michaël
>> 2016-05-09 11:07 GMT+02:00 kimaidou < <kimaidou at gmail.com>
>>> I forgot to mention the steps to reproduce the bug, and the precautions
>>> to take :
>>> * open the project in QGIS 2.14 ( I have not tested with older versions)
>>> * open a terminal and use this kind of command to monitor QGIS memory
>>> consumption : htop, or ps with
>>> watch -n1 'ps -aux --sort -pmem | head -5'
>>> * Navigate through the project by zooming in and out, pan, etc. I think
>>> you emphasize the memory leak by displaying the layer at small scale ( with
>>> many buildings displayed)
>>> * Be aware that this will increase the memory, so keep an eye on the
>>> memory consumption so that your system has enough free memory to work
>>> properly.
>>> Michaël
>>> 2016-05-09 11:00 GMT+02:00 kimaidou < <kimaidou at gmail.com>
>>>> Hi devs,
>>>> I have just found a memory leak in QGIS Desktop (and server) with the
>>>> project available in [1] ( a 20Mo tar.bz2 )
>>>> This is a very simple project with only one buildings Shapefile ( SHP
>>>> 68Mo). This layer has been exported from PostGIS from a query wich aimed to
>>>> simplify the building for fast rendering.
>>>> The geometries have been simplified ( I used SnapToGrid, then
>>>> (St_Dump(St_Union(a.geom))) to remove as many nodes as possible )
>>>> The layers has ~ 700 000 features.
>>>> Has anyone encoutered such a leak ?
>>>> [1]
>>>> https://framadrop.org/r/_7VsZtvzdU#+eJHHPPOIdVcgj/AUp8V91T9m6gmO7/XCh6uOhzP7ro=
>>>> Cheers,
>>>> Michaël
> Qgis-developer mailing listQgis-developer at lists.osgeo.org
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160509/0f240238/attachment-0001.html>
