[Qgis-developer] Compile error with latest gdal
Stefan Ziegler
stefan.ziegler.de at gmail.com
Wed May 11 05:58:58 PDT 2016
Yes, I deleted the build directory. But still same error.
Stefan
On Wed, May 11, 2016 at 1:47 PM, Werner Macho <werner.macho at gmail.com>
wrote:
> Hi Stefan,
> Did you already try to start with a complete new build directory? And
> in case of using ccache delete the compiler cache?
> regards
> Werner
> On Wed, May 11, 2016 at 1:40 PM, Stefan Ziegler
> <stefan.ziegler.de at gmail.com> wrote:
> > Hi
> > I get some errors when compiling QGIS master against GDAL master on
> Ubuntu
> > 16.04:
> > [ 64%] Built target postgresprovider
> > [ 64%] Linking CXX executable ../../output/bin/crssync
> > /usr/local/gdal_master/lib/libgdal.so: undefined reference to
> > `IVFKDataBlock::GetFeatureCount()'
> > collect2: error: ld returned 1 exit status
> > src/crssync/CMakeFiles/crssync.dir/build.make:112: recipe for target
> > 'output/bin/crssync' failed
> > make[2]: *** [output/bin/crssync] Error 1
> > CMakeFiles/Makefile2:1632: recipe for target
> > 'src/crssync/CMakeFiles/crssync.dir/all' failed
> > make[1]: *** [src/crssync/CMakeFiles/crssync.dir/all] Error 2
> > Makefile:149: recipe for target 'all' failed
> > make: *** [all] Error 2
> > regards
> > Stefan
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160511/3708ad66/attachment-0001.html>
