[Qgis-developer] update QgsDataDefinedButton with QgsMapLayerComboBox
matteo matteo.ghetta at gmail.com
Wed May 11 06:07:18 PDT 2016
Hi Denis,
thanks (again) for the answer..
> look at QgsDataDefinedButton::init
> That should set up the button for a layer.
> It is not a slot though, not sure if you can connect this directly, you
> might need to create an intermediate method.
ok so you think something like
self.dataDefined.__init__(vl=self.LayerCombo.currentLayer())
to put in the __init__ method of the class right?
Thanks again
Matteo
