[Qgis-developer] GEOS error Exception: IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
A Huarte
ahuarte47 at yahoo.es
Fri May 13 01:08:42 PDT 2016
Hi, I think this pull https://github.com/qgis/QGIS/pull/2900 fixes the error.
But it is pending to merge, It needs to fix some tests to be accepted finally.Meanwhile you can disable the on-the-fly simplification of the layer.
Kind regardsAlvaro
De: Janneke van Dijk <janneke.qgis at gmail.com>
Para: qgis-developer at lists.osgeo.org
Enviado: Viernes 13 de Mayo de 2016 9:53
Asunto: [Qgis-developer] GEOS error Exception: IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
Dear list,
Using QGIS 2.14.2 on Windows 7 I get the following error message when
zooming out on a shapefile layer that has labels switched on:
It seems to be an old bug (https://hub.qgis.org/issues/9375) that was
fixed 2 years ago.
It doesn't seem to cause any problems otherwise. Anyone else have this
issue? Should I file a new bug report?
Regards,
Janneke
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160513/37bc5c15/attachment.html>
