[Qgis-developer] GEOS error Exception: IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
Janneke van Dijk
janneke.qgis at gmail.com
Sat May 14 11:30:41 PDT 2016
Hi Alvaro,
How do I disable the on-the-fly simplification?
Do I understand it correctly that the error causes problems with a
virtual field with a geometry calculation in it? Would that also be
solved by disabling on-the-fly simplification? Or should I avoid the
issues by not making it a virtual field - if I know that the polygons
won't be edited?
Thanks for your insights,
Janneke
On 13/05/2016 11:08, A Huarte wrote:
> Hi, I think this pull https://github.com/qgis/QGIS/pull/2900 fixes the
> error.
> But it is pending to merge, It needs to fix some tests to be accepted
> finally.
> Meanwhile you can disable the on-the-fly simplification of the layer.
> Kind regards
> Alvaro
> *De:* Janneke van Dijk <janneke.qgis at gmail.com>
> *Para:* qgis-developer at lists.osgeo.org
> *Enviado:* Viernes 13 de Mayo de 2016 9:53
> *Asunto:* [Qgis-developer] GEOS error Exception:
> Dear list,
> Using QGIS 2.14.2 on Windows 7 I get the following error message when
> zooming out on a shapefile layer that has labels switched on:
> GEOS
> It seems to be an old bug (https://hub.qgis.org/issues/9375) that was
> fixed 2 years ago.
> It doesn't seem to cause any problems otherwise. Anyone else have this
> issue? Should I file a new bug report?
> Regards,
> Janneke
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160514/0d872044/attachment.html>
