[Qgis-developer] GEOS error Exception: IllegalArgumentException: Invalid number of points in LinearRing found 3 - must be 0 or >= 4
John Layt jlayt at kde.org
Sat May 14 12:28:12 PDT 2016
> On 13/05/2016 11:08, A Huarte wrote:
> Hi, I think this pull https://github.com/qgis/QGIS/pull/2900 fixes the
> error.
> But it is pending to merge, It needs to fix some tests to be accepted
> finally.
> Meanwhile you can disable the on-the-fly simplification of the layer.
Ah, now that would make sense why I could never find a bad geometry in
my data if if was the simplified geometry that was in error. Won't
waste anymore time chasing that one then :-)
John.
