[Qgis-developer] Memory leak in QGIS 2.14 with a Shapefile
kimaidou
kimaidou at gmail.com
Sat May 14 02:39:38 PDT 2016
Hi Nyall,
I have just tested it with today's master, and there is no memory leak any
more. Thanks a lot for helping solving this nasty one.
Could you please backport the related "memory leak" commits to the 2.14
release branch ?
Cheers,
Michaël
2016-05-10 14:10 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Thanks Nyall,
> I will build last master and check it asap.
> Cheers,
> Michaël
> 2016-05-10 6:25 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
>> On 10 May 2016 at 03:38, kimaidou <kimaidou at gmail.com> wrote:
>> > Hi
>> > I just tested with a freshly built QGIS release-2_14 , and the issue
>> > remains.
>> > The easiest way to reproduce is to zoom back and forth from big scales
>> > 1:25 000 ) to layer extent scale ( ~ 1:600 000 )
>> Should be fixed by
>> https://github.com/qgis/QGIS/commit/6b80518a5b55ab30fb19493266d5626d0f89d26b
>> There was a leak in the OGR provider when a feature had null geometry
>> and a filter rect was set on a feature request (such as when rendering
>> a map).
>> I also fixed another (potentially huge?) memory leak in the python code.
>> Would appreciate testing and feedback on whether this has made a big
>> difference for you!
>> Nyall
>> > Good evening/morning
>> > Michaël
>> > 2016-05-09 15:02 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>> >> Hi Matthias,
>> >> Not yet, I need to build QGIS master before being able to report back
>> >> Thanks for your answer
>> >> 2016-05-09 14:59 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
>> >>> Have you tested with either the latest 2.14 nightly or master nightly?
>> >>> An issue with OGR connection pooling has been resolved recently. And I
>> >>> wonder if that could be related.
>> >>> -- Matthias
>> >>> On 05/09/2016 02:28 PM, kimaidou wrote:
>> >>> I created an issue about it : http://hub.qgis.org/issues/14792
>> >>> 2016-05-09 11:48 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>> >>>> Hi again,
>> >>>> I also forgot to mention that I have no memory leak when using the
>> same
>> >>>> dataset in PostGIS ( tested by importing the Shapefile in PostGIS
>> with
>> >>>> shape2pgsql )
>> >>>> Michaël
>> >>>> 2016-05-09 11:07 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>> >>>>> I forgot to mention the steps to reproduce the bug, and the
>> precautions
>> >>>>> to take :
>> >>>>> * open the project in QGIS 2.14 ( I have not tested with older
>> >>>>> versions)
>> >>>>> * open a terminal and use this kind of command to monitor QGIS
>> memory
>> >>>>> consumption : htop, or ps with
>> >>>>> watch -n1 'ps -aux --sort -pmem | head -5'
>> >>>>> * Navigate through the project by zooming in and out, pan, etc. I
>> think
>> >>>>> you emphasize the memory leak by displaying the layer at small
>> scale ( with
>> >>>>> many buildings displayed)
>> >>>>> * Be aware that this will increase the memory, so keep an eye on the
>> >>>>> memory consumption so that your system has enough free memory to
>> work
>> >>>>> properly.
>> >>>>> Michaël
>> >>>>> 2016-05-09 11:00 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>> >>>>>> Hi devs,
>> >>>>>> I have just found a memory leak in QGIS Desktop (and server) with
>> the
>> >>>>>> project available in [1] ( a 20Mo tar.bz2 )
>> >>>>>> This is a very simple project with only one buildings Shapefile (
>> SHP
>> >>>>>> 68Mo). This layer has been exported from PostGIS from a query wich
>> aimed to
>> >>>>>> simplify the building for fast rendering.
>> >>>>>> The geometries have been simplified ( I used SnapToGrid, then
>> >>>>>> (St_Dump(St_Union(a.geom))) to remove as many nodes as possible )
>> >>>>>> The layers has ~ 700 000 features.
>> >>>>>> Has anyone encoutered such a leak ?
>> >>>>>> [1]
>> https://framadrop.org/r/_7VsZtvzdU#+eJHHPPOIdVcgj/AUp8V91T9m6gmO7/XCh6uOhzP7ro=
>> >>>>>> Cheers,
>> >>>>>> Michaël
>> >>> _______________________________________________
>> >>> Qgis-developer mailing list
>> >>> Qgis-developer at lists.osgeo.org
>> >>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >>> Matthias Kuhn
>> >>> OPENGIS.ch - https://www.opengis.ch
>> >>> Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160514/f57faac1/attachment.html>
