[Qgis-developer] Memory leak in QGIS 2.14 with a Shapefile
Nyall Dawson
nyall.dawson at gmail.com
Sat May 14 03:41:56 PDT 2016
On 14 May 2016 19:39, "kimaidou" <kimaidou at gmail.com> wrote:
> Hi Nyall,
> I have just tested it with today's master, and there is no memory leak
any more. Thanks a lot for helping solving this nasty one.
> Could you please backport the related "memory leak" commits to the 2.14
release branch ?
Thanks for the confirmation. I'll backport sometime next week (got a bunch
of commits I need to do this for)
Nyall
> Cheers,
> Michaël
> 2016-05-10 14:10 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>> Thanks Nyall,
>> I will build last master and check it asap.
>> Cheers,
>> Michaël
>> 2016-05-10 6:25 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
>>> On 10 May 2016 at 03:38, kimaidou <kimaidou at gmail.com> wrote:
>>> > Hi
>>> > I just tested with a freshly built QGIS release-2_14 , and the issue
>>> > remains.
>>> > The easiest way to reproduce is to zoom back and forth from big
scales ( ~
>>> > 1:25 000 ) to layer extent scale ( ~ 1:600 000 )
>>> Should be fixed by
https://github.com/qgis/QGIS/commit/6b80518a5b55ab30fb19493266d5626d0f89d26b
>>> There was a leak in the OGR provider when a feature had null geometry
>>> and a filter rect was set on a feature request (such as when rendering
>>> a map).
>>> I also fixed another (potentially huge?) memory leak in the python code.
>>> Would appreciate testing and feedback on whether this has made a big
>>> difference for you!
>>> Nyall
>>> > Good evening/morning
>>> > Michaël
>>> > 2016-05-09 15:02 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>>> >> Hi Matthias,
>>> >> Not yet, I need to build QGIS master before being able to report back
>>> >> Thanks for your answer
>>> >> 2016-05-09 14:59 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
>>> >>> Have you tested with either the latest 2.14 nightly or master
nightly?
>>> >>> An issue with OGR connection pooling has been resolved recently.
And I
>>> >>> wonder if that could be related.
>>> >>> -- Matthias
>>> >>> On 05/09/2016 02:28 PM, kimaidou wrote:
>>> >>> I created an issue about it : http://hub.qgis.org/issues/14792
>>> >>> 2016-05-09 11:48 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>>> >>>> Hi again,
>>> >>>> I also forgot to mention that I have no memory leak when using the
same
>>> >>>> dataset in PostGIS ( tested by importing the Shapefile in PostGIS
with
>>> >>>> shape2pgsql )
>>> >>>> Michaël
>>> >>>> 2016-05-09 11:07 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>>> >>>>> I forgot to mention the steps to reproduce the bug, and the
precautions
>>> >>>>> to take :
>>> >>>>> * open the project in QGIS 2.14 ( I have not tested with older
>>> >>>>> versions)
>>> >>>>> * open a terminal and use this kind of command to monitor QGIS
memory
>>> >>>>> consumption : htop, or ps with
>>> >>>>> watch -n1 'ps -aux --sort -pmem | head -5'
>>> >>>>> * Navigate through the project by zooming in and out, pan, etc. I
think
>>> >>>>> you emphasize the memory leak by displaying the layer at small
scale ( with
>>> >>>>> many buildings displayed)
>>> >>>>> * Be aware that this will increase the memory, so keep an eye on
the
>>> >>>>> memory consumption so that your system has enough free memory to
work
>>> >>>>> properly.
>>> >>>>> Michaël
>>> >>>>> 2016-05-09 11:00 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>>> >>>>>> Hi devs,
>>> >>>>>> I have just found a memory leak in QGIS Desktop (and server)
with the
>>> >>>>>> project available in [1] ( a 20Mo tar.bz2 )
>>> >>>>>> This is a very simple project with only one buildings Shapefile
( SHP
>>> >>>>>> 68Mo). This layer has been exported from PostGIS from a query
wich aimed to
>>> >>>>>> simplify the building for fast rendering.
>>> >>>>>> The geometries have been simplified ( I used SnapToGrid, then
>>> >>>>>> (St_Dump(St_Union(a.geom))) to remove as many nodes as possible
>>> >>>>>> The layers has ~ 700 000 features.
>>> >>>>>> Has anyone encoutered such a leak ?
>>> >>>>>> [1]
https://framadrop.org/r/_7VsZtvzdU#+eJHHPPOIdVcgj/AUp8V91T9m6gmO7/XCh6uOhzP7ro=
>>> >>>>>> Cheers,
>>> >>>>>> Michaël
>>> >>> _______________________________________________
>>> >>> Qgis-developer mailing list
>>> >>> Qgis-developer at lists.osgeo.org
>>> >>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> >>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> >>> Matthias Kuhn
>>> >>> OPENGIS.ch - https://www.opengis.ch
>>> >>> Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160514/b1b1f63e/attachment-0001.html>
