[Qgis-developer] Memory leak in QGIS 2.14 with a Shapefile
kimaidou
kimaidou at gmail.com
Sat May 14 05:57:56 PDT 2016
Ok, thanks a lot !
2016-05-14 12:41 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 14 May 2016 19:39, "kimaidou" <kimaidou at gmail.com> wrote:
> > Hi Nyall,
> > I have just tested it with today's master, and there is no memory leak
> any more. Thanks a lot for helping solving this nasty one.
> > Could you please backport the related "memory leak" commits to the 2.14
> release branch ?
> Thanks for the confirmation. I'll backport sometime next week (got a bunch
> of commits I need to do this for)
> Nyall
> > Cheers,
> > Michaël
> > 2016-05-10 14:10 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> >> Thanks Nyall,
> >> I will build last master and check it asap.
> >> Cheers,
> >> Michaël
> >> 2016-05-10 6:25 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> >>> On 10 May 2016 at 03:38, kimaidou <kimaidou at gmail.com> wrote:
> >>> > Hi
> >>> > I just tested with a freshly built QGIS release-2_14 , and the issue
> >>> > remains.
> >>> > The easiest way to reproduce is to zoom back and forth from big
> scales ( ~
> >>> > 1:25 000 ) to layer extent scale ( ~ 1:600 000 )
> >>> Should be fixed by
> https://github.com/qgis/QGIS/commit/6b80518a5b55ab30fb19493266d5626d0f89d26b
> >>> There was a leak in the OGR provider when a feature had null geometry
> >>> and a filter rect was set on a feature request (such as when rendering
> >>> a map).
> >>> I also fixed another (potentially huge?) memory leak in the python
> code.
> >>> Would appreciate testing and feedback on whether this has made a big
> >>> difference for you!
> >>> Nyall
> >>> > Good evening/morning
> >>> > Michaël
> >>> > 2016-05-09 15:02 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> >>> >> Hi Matthias,
> >>> >> Not yet, I need to build QGIS master before being able to report
> back
> >>> >> Thanks for your answer
> >>> >> 2016-05-09 14:59 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
> >>> >>> Have you tested with either the latest 2.14 nightly or master
> nightly?
> >>> >>> An issue with OGR connection pooling has been resolved recently.
> And I
> >>> >>> wonder if that could be related.
> >>> >>> -- Matthias
> >>> >>> On 05/09/2016 02:28 PM, kimaidou wrote:
> >>> >>> I created an issue about it : http://hub.qgis.org/issues/14792
> >>> >>> 2016-05-09 11:48 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> >>> >>>> Hi again,
> >>> >>>> I also forgot to mention that I have no memory leak when using
> the same
> >>> >>>> dataset in PostGIS ( tested by importing the Shapefile in PostGIS
> with
> >>> >>>> shape2pgsql )
> >>> >>>> Michaël
> >>> >>>> 2016-05-09 11:07 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> >>> >>>>> I forgot to mention the steps to reproduce the bug, and the
> precautions
> >>> >>>>> to take :
> >>> >>>>> * open the project in QGIS 2.14 ( I have not tested with older
> >>> >>>>> versions)
> >>> >>>>> * open a terminal and use this kind of command to monitor QGIS
> memory
> >>> >>>>> consumption : htop, or ps with
> >>> >>>>> watch -n1 'ps -aux --sort -pmem | head -5'
> >>> >>>>> * Navigate through the project by zooming in and out, pan, etc.
> I think
> >>> >>>>> you emphasize the memory leak by displaying the layer at small
> scale ( with
> >>> >>>>> many buildings displayed)
> >>> >>>>> * Be aware that this will increase the memory, so keep an eye on
> the
> >>> >>>>> memory consumption so that your system has enough free memory to
> work
> >>> >>>>> properly.
> >>> >>>>> Michaël
> >>> >>>>> 2016-05-09 11:00 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> >>> >>>>>> Hi devs,
> >>> >>>>>> I have just found a memory leak in QGIS Desktop (and server)
> with the
> >>> >>>>>> project available in [1] ( a 20Mo tar.bz2 )
> >>> >>>>>> This is a very simple project with only one buildings Shapefile
> ( SHP
> >>> >>>>>> 68Mo). This layer has been exported from PostGIS from a query
> wich aimed to
> >>> >>>>>> simplify the building for fast rendering.
> >>> >>>>>> The geometries have been simplified ( I used SnapToGrid, then
> >>> >>>>>> (St_Dump(St_Union(a.geom))) to remove as many nodes as
> possible )
> >>> >>>>>> The layers has ~ 700 000 features.
> >>> >>>>>> Has anyone encoutered such a leak ?
> >>> >>>>>> [1]
> https://framadrop.org/r/_7VsZtvzdU#+eJHHPPOIdVcgj/AUp8V91T9m6gmO7/XCh6uOhzP7ro=
> >>> >>>>>> Cheers,
> >>> >>>>>> Michaël
> >>> >>> _______________________________________________
> >>> >>> Qgis-developer mailing list
> >>> >>> Qgis-developer at lists.osgeo.org
> >>> >>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> >>> Unsubscribe:
> >>> >>> Matthias Kuhn
> >>> >>> OPENGIS.ch - https://www.opengis.ch
> >>> >>> Spatial • (Q)GIS • PostGIS • Open Source
> >>> >>> Unsubscribe:
> >>> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160514/56ce68f8/attachment.html>
