[Qgis-developer] editing expressions defining virtual fields seems erratic
Janneke van Dijk
janneke.qgis at gmail.com
Mon May 16 04:24:40 PDT 2016
Dear list,
In a polygon shapefile I'm seeing inconstistent behaviour in virtual
fields. The attached project and shapefile has reduced it to it's
simplest form: the shapefile contains two virtual fields, the first one
containing the expression 1 (integer) and the second the expression 2
(integer). However, when I want to edit the expression for the fields,
the first field does not give a problem. For the second field I click on
the 'expression' to open the expression builder, but the expression
shown in the expression builder equals 1. I have not been able to find
any pattern in when it happens/for what type of expressions. This
example is the most simple form of the unexpected behaviour, but I have
seen it with more complicated expressions as well. Sometimes after
trying to edit one of these 'erratic' expressions QGIS closes with a
minidump being written error message. Again, not always.
Anyone have any idea why this might happen and how to work around it?
Looking forward to some thoughts...
Janneke
On 13/05/2016 11:36, Nyall Dawson wrote:
> On 13 May 2016 at 17:53, Janneke van Dijk<janneke.qgis at gmail.com> wrote:
>> Dear list,
>> Using QGIS 2.14.2 on Windows 7 I get the following error message when
>> zooming out on a shapefile layer that has labels switched on:
>> GEOS
>> Exception: IllegalArgumentException: Invalid number of points in LinearRing
>> found 3 - must be 0 or >= 4
>> It seems to be an old bug (https://hub.qgis.org/issues/9375) that was fixed
>> 2 years ago.
>> It doesn't seem to cause any problems otherwise. Anyone else have this
>> issue? Should I file a new bug report?
> Hi Janneke,
> Best thing to do is file an issue athttp://hub.qgis.org/issues with a
> copy of your data + sample project. If you do that this bug should be
> easy for us to squash!
> Thanks,
> Nyall
>> Regards,
>> Janneke
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-developer
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160516/a7073547/attachment.zip>
