[Qgis-developer] editing expressions defining virtual fields seems erratic
Matthias Kuhn
matthias at opengis.ch
Mon May 16 06:05:13 PDT 2016
On 05/16/2016 01:24 PM, Janneke van Dijk wrote:
> Dear list,
> In a polygon shapefile I'm seeing inconstistent behaviour in virtual
> fields. The attached project and shapefile has reduced it to it's
> simplest form: the shapefile contains two virtual fields, the first
> one containing the expression 1 (integer) and the second the
> expression 2 (integer). However, when I want to edit the expression
> for the fields, the first field does not give a problem. For the
> second field I click on the 'expression' to open the expression
> builder, but the expression shown in the expression builder equals 1.
> I have not been able to find any pattern in when it happens/for what
> type of expressions. This example is the most simple form of the
> unexpected behaviour, but I have seen it with more complicated
> expressions as well. Sometimes after trying to edit one of these
> 'erratic' expressions QGIS closes with a minidump being written error
> message. Again, not always.
> Anyone have any idea why this might happen and how to work around it?
Fixed in master
> Looking forward to some thoughts...
> Janneke
> On 13/05/2016 11:36, Nyall Dawson wrote:
>> On 13 May 2016 at 17:53, Janneke van Dijk<janneke.qgis at gmail.com>
>> wrote:
>>> Dear list,
>>> Using QGIS 2.14.2 on Windows 7 I get the following error message when
>>> zooming out on a shapefile layer that has labels switched on:
>>> GEOS
>>> Exception: IllegalArgumentException: Invalid number of points in
>>> LinearRing
>>> found 3 - must be 0 or >= 4
>>> It seems to be an old bug (https://hub.qgis.org/issues/9375) that
>>> was fixed
>>> 2 years ago.
>>> It doesn't seem to cause any problems otherwise. Anyone else have this
>>> issue? Should I file a new bug report?
>> Hi Janneke,
>> Best thing to do is file an issue athttp://hub.qgis.org/issues with a
>> copy of your data + sample project. If you do that this bug should be
>> easy for us to squash!
>> Thanks,
>> Nyall
>>> Regards,
>>> Janneke
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160516/625d63aa/attachment.html>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160516/625d63aa/attachment.sig>
