[Qgis-developer] editing expressions defining virtual fields seems erratic
Janneke van Dijk
janneke.qgis at gmail.com
Mon May 16 12:49:50 PDT 2016
Hi Mathias,
I've tried installing the dev version and I think that that worked (this
is what 'about' shows).
QGIS version
2.15.0-Master
QGIS code revision
3d44a1e <https://github.com/qgis/QGIS/commit/3d44a1e>
Compiled against Qt
4.8.5
Running against Qt
4.8.5
Compiled against GDAL/OGR
2.0.2
Running against GDAL/OGR
2.0.2
Compiled against GEOS
3.5.0-CAPI-1.9.0
Running against GEOS
3.5.0-CAPI-1.9.0 r4084
PostgreSQL Client Version
9.2.4
SpatiaLite Version
4.3.0
QWT Version
5.2.3
PROJ.4 Version
492
QScintilla2 Version
2.7.2
This copy of QGIS writes debugging output.
I started with a new project, added the tst shapefile again, repeated
the process of adding the virtual fields. The problem persists. Am I
overlooking something?
Thanks for your help!
Janneke
On 16/05/2016 16:05, Matthias Kuhn wrote:
> On 05/16/2016 01:24 PM, Janneke van Dijk wrote:
>> Dear list,
>> In a polygon shapefile I'm seeing inconstistent behaviour in virtual
>> fields. The attached project and shapefile has reduced it to it's
>> simplest form: the shapefile contains two virtual fields, the first
>> one containing the expression 1 (integer) and the second the
>> expression 2 (integer). However, when I want to edit the expression
>> for the fields, the first field does not give a problem. For the
>> second field I click on the 'expression' to open the expression
>> builder, but the expression shown in the expression builder equals 1.
>> I have not been able to find any pattern in when it happens/for what
>> type of expressions. This example is the most simple form of the
>> unexpected behaviour, but I have seen it with more complicated
>> expressions as well. Sometimes after trying to edit one of these
>> 'erratic' expressions QGIS closes with a minidump being written error
>> message. Again, not always.
>> Anyone have any idea why this might happen and how to work around it?
> Fixed in master
>> Looking forward to some thoughts...
>> Janneke
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160516/795a0d49/attachment.html>
