[Qgis-developer] editing expressions defining virtual fields seems erratic
Andreas Neumann a.neumann at carto.net
Mon May 16 13:13:38 PDT 2016
Hi Janneke,
Your build is a bit older than Matthias fix - please try again with
tomorrow's nightly build or compile yourself.
Matthias fix is at
https://github.com/qgis/QGIS/commit/c0214bc30148b7da272917d73afc1820b78c1d3e
(7h ago) - your build is 22h old.
Greetings,
Andreas
On 16.05.2016 21:49, Janneke van Dijk wrote:
> Hi Mathias,
> I've tried installing the dev version and I think that that worked
> (this is what 'about' shows).
> QGIS version
> 2.15.0-Master
> QGIS code revision
> 3d44a1e <https://github.com/qgis/QGIS/commit/3d44a1e>
> Compiled against Qt
> 4.8.5
> Running against Qt
> 4.8.5
> Compiled against GDAL/OGR
> 2.0.2
> Running against GDAL/OGR
> 2.0.2
> Compiled against GEOS
> 3.5.0-CAPI-1.9.0
> Running against GEOS
> 3.5.0-CAPI-1.9.0 r4084
> PostgreSQL Client Version
> 9.2.4
> SpatiaLite Version
> 4.3.0
> QWT Version
> 5.2.3
> PROJ.4 Version
> 492
> QScintilla2 Version
> 2.7.2
> This copy of QGIS writes debugging output.
> I started with a new project, added the tst shapefile again, repeated
> the process of adding the virtual fields. The problem persists. Am I
> overlooking something?
> Thanks for your help!
> Janneke
> On 16/05/2016 16:05, Matthias Kuhn wrote:
>> On 05/16/2016 01:24 PM, Janneke van Dijk wrote:
>>> Dear list,
>>> In a polygon shapefile I'm seeing inconstistent behaviour in virtual
>>> fields. The attached project and shapefile has reduced it to it's
>>> simplest form: the shapefile contains two virtual fields, the first
>>> one containing the expression 1 (integer) and the second the
>>> expression 2 (integer). However, when I want to edit the expression
>>> for the fields, the first field does not give a problem. For the
>>> second field I click on the 'expression' to open the expression
>>> builder, but the expression shown in the expression builder equals
>>> 1. I have not been able to find any pattern in when it happens/for
>>> what type of expressions. This example is the most simple form of
>>> the unexpected behaviour, but I have seen it with more complicated
>>> expressions as well. Sometimes after trying to edit one of these
>>> 'erratic' expressions QGIS closes with a minidump being written
>>> error message. Again, not always.
>>> Anyone have any idea why this might happen and how to work around it?
>> Fixed in master
>>> Looking forward to some thoughts...
>>> Janneke
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160516/b7f844a4/attachment-0001.html>
