[Qgis-developer] editing expressions defining virtual fields seems erratic
Janneke van Dijk janneke.qgis at gmail.com
Mon May 16 23:41:11 PDT 2016
Hi Andreas and Mathias,
Tried it again this morning, and indeed, it works!
Thanks a lot for the quick solution!
Janneke
On 16/05/2016 23:13, Andreas Neumann wrote:
> Hi Janneke,
> Your build is a bit older than Matthias fix - please try again with
> tomorrow's nightly build or compile yourself.
> Matthias fix is at
> https://github.com/qgis/QGIS/commit/c0214bc30148b7da272917d73afc1820b78c1d3e
> (7h ago) - your build is 22h old.
> Greetings,
> Andreas
> On 16.05.2016 21:49, Janneke van Dijk wrote:
>> Hi Mathias,
>> I've tried installing the dev version and I think that that worked
>> (this is what 'about' shows).
>> QGIS version
>> 2.15.0-Master
>> QGIS code revision
>> 3d44a1e <https://github.com/qgis/QGIS/commit/3d44a1e>
>> Compiled against Qt
>> 4.8.5
>> Running against Qt
>> 4.8.5
>> Compiled against GDAL/OGR
>> 2.0.2
>> Running against GDAL/OGR
>> 2.0.2
>> Compiled against GEOS
>> 3.5.0-CAPI-1.9.0
>> Running against GEOS
>> 3.5.0-CAPI-1.9.0 r4084
>> PostgreSQL Client Version
>> 9.2.4
>> SpatiaLite Version
>> 4.3.0
>> QWT Version
>> 5.2.3
>> PROJ.4 Version
>> 492
>> QScintilla2 Version
>> 2.7.2
>> This copy of QGIS writes debugging output.
>> I started with a new project, added the tst shapefile again, repeated
>> the process of adding the virtual fields. The problem persists. Am I
>> overlooking something?
>> Thanks for your help!
>> Janneke
>> On 16/05/2016 16:05, Matthias Kuhn wrote:
>>> On 05/16/2016 01:24 PM, Janneke van Dijk wrote:
>>>> Dear list,
>>>> In a polygon shapefile I'm seeing inconstistent behaviour in
>>>> virtual fields. The attached project and shapefile has reduced it
>>>> to it's simplest form: the shapefile contains two virtual fields,
>>>> the first one containing the expression 1 (integer) and the second
>>>> the expression 2 (integer). However, when I want to edit the
>>>> expression for the fields, the first field does not give a problem.
>>>> For the second field I click on the 'expression' to open the
>>>> expression builder, but the expression shown in the expression
>>>> builder equals 1. I have not been able to find any pattern in when
>>>> it happens/for what type of expressions. This example is the most
>>>> simple form of the unexpected behaviour, but I have seen it with
>>>> more complicated expressions as well. Sometimes after trying to
>>>> edit one of these 'erratic' expressions QGIS closes with a minidump
>>>> being written error message. Again, not always.
>>>> Anyone have any idea why this might happen and how to work around it?
>>> Fixed in master
>>>> Looking forward to some thoughts...
>>>> Janneke
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-developer
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160517/1c23db5a/attachment-0001.html>
