[Qgis-developer] GRASS Plugin Delete vector issue in windows
Radim Blazek
radim.blazek at gmail.com
Wed May 18 06:03:12 PDT 2016
On Thu, Apr 21, 2016 at 8:45 AM, roy roy <royroge at outlook.com> wrote:
> Ok thanks Nyall,
> so what do you suggest to do about this,
> i think it's really quite a issue although it
> happens only on windows ...
I fixed that today in bbaef371. The code which should close the map
was commented, which resulted in keeping the file open and
impossibility to delete the vector on Windows. Please test with the
next build.
There was a comment about possible dead-lock, so please pay attention
to possible freeze when a GRASS vector is deleted and fill a new bug
in such case. I hope it is OK however.
Radim
> Il 18/04/2016 12:10, Nyall Dawson ha scritto:
> On 18 Apr 2016 19:42, "roy roy" <royroge at outlook.com> wrote:
>> Can anyone confirm this issue with GRASS Plugin on:
>> Windows 64/32bit with QGIS 2.14.1 and Master
>> GRASS 7.0.3 GRASS Plugin
>> If you load a vector layer from GRASS DB in QGIS Layers Panel,
>> then you remove it from the panel, still it is impossible to
>> delete the vector from GRASS DB using the Browser Panel delete function.
> I can confirm - this happened to me last week on a Windows build.
> Nyall
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
