[Qgis-developer] GRASS Plugin Delete vector issue in windows
roy roy royroge at outlook.com
Wed May 18 08:03:06 PDT 2016
Thanks Radim,
i will text with next build !
Il 18/05/2016 15:03, Radim Blazek ha scritto:
> On Thu, Apr 21, 2016 at 8:45 AM, roy roy <royroge at outlook.com> wrote:
>> Ok thanks Nyall,
>> so what do you suggest to do about this,
>> i think it's really quite a issue although it
>> happens only on windows ...
> I fixed that today in bbaef371. The code which should close the map
> was commented, which resulted in keeping the file open and
> impossibility to delete the vector on Windows. Please test with the
> next build.
> There was a comment about possible dead-lock, so please pay attention
> to possible freeze when a GRASS vector is deleted and fill a new bug
> in such case. I hope it is OK however.
> Radim
>> Il 18/04/2016 12:10, Nyall Dawson ha scritto:
>> On 18 Apr 2016 19:42, "roy roy" <royroge at outlook.com> wrote:
>>> Can anyone confirm this issue with GRASS Plugin on:
>>> Windows 64/32bit with QGIS 2.14.1 and Master
>>> GRASS 7.0.3 GRASS Plugin
>>> If you load a vector layer from GRASS DB in QGIS Layers Panel,
>>> then you remove it from the panel, still it is impossible to
>>> delete the vector from GRASS DB using the Browser Panel delete function.
>> I can confirm - this happened to me last week on a Windows build.
>> Nyall
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
