[Qgis-developer] GRASS Plugin Delete vector issue in windows
roy roy
royroge at outlook.com
Thu May 19 00:34:45 PDT 2016
Using osgeo4w64 I installed several packages, there is no GRASS Plugin:
QGIS 2.15 nightly with grass 7.0.4
QGIS 2.14.2 nightly with grass 7.0.4
tried also to revert back to GRASS 7.0.3 but there is no GRASS Plugin;
so for this reason, sadly, i cannot test your patch Radim, i'll do ASAP.
### P.S.
I notice that this "GRASS Plugin not being present" issue
is quite annoying, so i wonder what is the policy of
osgeo4w package update/upgrade? Should we consider the
network installer a developer tool and use the sandalone installer
for QGIS regular use instead?
QGIS and GRASS along with GRASS Plugin have became powerful
tools and I understand that ***a lot*** of work is done by developers to
develop, maintain, package, document and release the software, **a lot
of valuable work(!)**;
sadly IMHO this random behaviour does not give justice to all the good
dev work.
I think a bit of well delivered information should make things better,
something
like the LTS release policy, now we normal users know that we can rely
on it to do
normal work, and we can use regular release to get the newest
functionalities.
Thanks again, Roy.
Il 18/05/2016 15:03, Radim Blazek ha scritto:
> On Thu, Apr 21, 2016 at 8:45 AM, roy roy <royroge at outlook.com> wrote:
>> Ok thanks Nyall,
>> so what do you suggest to do about this,
>> i think it's really quite a issue although it
>> happens only on windows ...
> I fixed that today in bbaef371. The code which should close the map
> was commented, which resulted in keeping the file open and
> impossibility to delete the vector on Windows. Please test with the
> next build.
> There was a comment about possible dead-lock, so please pay attention
> to possible freeze when a GRASS vector is deleted and fill a new bug
> in such case. I hope it is OK however.
> Radim
>> Il 18/04/2016 12:10, Nyall Dawson ha scritto:
>> On 18 Apr 2016 19:42, "roy roy" <royroge at outlook.com> wrote:
>>> Can anyone confirm this issue with GRASS Plugin on:
>>> Windows 64/32bit with QGIS 2.14.1 and Master
>>> GRASS 7.0.3 GRASS Plugin
>>> If you load a vector layer from GRASS DB in QGIS Layers Panel,
>>> then you remove it from the panel, still it is impossible to
>>> delete the vector from GRASS DB using the Browser Panel delete function.
>> I can confirm - this happened to me last week on a Windows build.
>> Nyall
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
