[Qgis-developer] Autotrace stopped working?
Paolo Cavallini
cavallini at faunalia.it
Fri May 20 23:44:13 PDT 2016
Il 21/05/2016 08:37, DelazJ ha scritto:
> Hi,
> Paolo, afaics, you need from time to time to click to confirm the shape
> of the polygon. The autotrace shows you, according to your mouse
> position (near a snappable node) what your poygon will look like,
> following the shortest path; it doesn't really draw it unless you click.
> For what i've experienced, the tracing helps you save a lot of common
> nodes click (Thank you, Martin) but you still need to click from time to
> time to make human choice.
Thanks Harrissou. The point is that the digitized polygon in my case
never follows the border of an existing one. Maybe I'm missing something
obvious here.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
