[Qgis-developer] GRASS Plugin Delete vector issue in windows
roy roy
royroge at outlook.com
Sat May 21 00:21:41 PDT 2016
Il 19/05/2016 10:30, Radim Blazek ha scritto:
> On Thu, May 19, 2016 at 9:34 AM, roy roy <royroge at outlook.com> wrote:
>> Using osgeo4w64 I installed several packages, there is no GRASS Plugin:
>> QGIS 2.15 nightly with grass 7.0.4
>> QGIS 2.14.2 nightly with grass 7.0.4
>> tried also to revert back to GRASS 7.0.3 but there is no GRASS Plugin;
>> so for this reason, sadly, i cannot test your patch Radim, i'll do ASAP.
> AFAIK, there was no GRASS 64bit in OSGeo4W, thus no plugin in 64 bit
> version. Try 32 bit build.
> Radim
Ok i'm testing OSGeo4W in 32 bit virtual machine, GRASS Plugin is not
showing up
on QGIS 2.0.15 nightly; anyway this is more an OSGEO installer issue
than a QGIS
issue i think.
>> ### P.S.
>> I notice that this "GRASS Plugin not being present" issue
>> is quite annoying, so i wonder what is the policy of
>> osgeo4w package update/upgrade? Should we consider the
>> network installer a developer tool and use the sandalone installer
>> for QGIS regular use instead?
>> QGIS and GRASS along with GRASS Plugin have became powerful
>> tools and I understand that ***a lot*** of work is done by developers to
>> develop, maintain, package, document and release the software, **a lot
>> of valuable work(!)**;
>> sadly IMHO this random behaviour does not give justice to all the good
>> dev work.
>> I think a bit of well delivered information should make things better,
>> something
>> like the LTS release policy, now we normal users know that we can rely
>> on it to do
>> normal work, and we can use regular release to get the newest
>> functionalities.
>> Thanks again, Roy.
>> Il 18/05/2016 15:03, Radim Blazek ha scritto:
>>> On Thu, Apr 21, 2016 at 8:45 AM, roy roy <royroge at outlook.com> wrote:
>>>> Ok thanks Nyall,
>>>> so what do you suggest to do about this,
>>>> i think it's really quite a issue although it
>>>> happens only on windows ...
>>> I fixed that today in bbaef371. The code which should close the map
>>> was commented, which resulted in keeping the file open and
>>> impossibility to delete the vector on Windows. Please test with the
>>> next build.
>>> There was a comment about possible dead-lock, so please pay attention
>>> to possible freeze when a GRASS vector is deleted and fill a new bug
>>> in such case. I hope it is OK however.
>>> Radim
>>>> Il 18/04/2016 12:10, Nyall Dawson ha scritto:
>>>> On 18 Apr 2016 19:42, "roy roy" <royroge at outlook.com> wrote:
>>>>> Can anyone confirm this issue with GRASS Plugin on:
>>>>> Windows 64/32bit with QGIS 2.14.1 and Master
>>>>> GRASS 7.0.3 GRASS Plugin
>>>>> If you load a vector layer from GRASS DB in QGIS Layers Panel,
>>>>> then you remove it from the panel, still it is impossible to
>>>>> delete the vector from GRASS DB using the Browser Panel delete function.
>>>> I can confirm - this happened to me last week on a Windows build.
>>>> Nyall
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
