[Qgis-developer] Processing - current status of "in-between" layers while running models
Paolo Cavallini
cavallini at faunalia.it
Sun May 22 22:32:34 PDT 2016
Il 22/05/2016 12:00, Blumentrath, Stefan ha scritto:
> Hei Paolo,
> See: http://hub.qgis.org/issues/14856
ggod idea; r.external is already used instead of import, using it also
for export will make things smoother
> Does not help for vector data, though...
> Yet, there is also: https://grass.osgeo.org/grass70/manuals/v.external.out.html
yes, the main problem is with vectors: v.external only supports a
limited set of commands (those not requiring topology), so reverting to
real import is generally necessary, and that's the time consuming step.
ideally, Processing should check the command sequence in a model, and
avoid export/import when two consecutive commands are from the same
software, particularly GRASS.
All the best, and thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
