[Qgis-developer] Moving the install instructions to a more sexy, visible, coherent and translatable page in qgis.org
DelazJ delazj at gmail.com
Tue May 17 02:46:29 PDT 2016
Hi all,
So, is any decision taken about this? Does it seem feasible?
Regards,
Harrissou
2016-04-25 17:19 GMT+02:00 Jürgen E. <jef at norbit.de>:
> Hi Richard,
> On Sat, 23. Apr 2016 at 16:53:46 +0200, Richard Duivenvoorde wrote:
> > @jef: maybe you can elaborate a little more on this?
> You're probably referring to scripts/scandeps.pl.  That updates the
> apt-get
> install lines in doc/linux.t2t from the packaging files in debian/
> But that's about it.  I'm not sure those are actually necessary - I'd try
> to
> keep specific versions from the descriptions if possible.  As that's what
> tend
> to outdate quickly and point to the packaging files instead, because those
> are
> actually used and maintained.
> BTW I for instance don't go through manually setting up the build with
> cmake
> for development, but produce packages once (or sometimes even kill the
> build
> half way) and keep using that build directory for development (both on
> linux
> and windows).
> On Debian that complains about what dependencies are missing anyway - so
> having
> the apt-get install list above isn't necessary.  You could also just add
> the
> nightly repository for the distribution you target and run apt-get
> build-dep
> qgis and achieve the same.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
> +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160517/ffa0a95c/attachment-0001.html>
