[Qgis-developer] crash when adding relation with incomplete parameters
Neumann, Andreas a.neumann at carto.net
Mon May 23 05:40:33 PDT 2016
Hi Lauri,
I had the same just recently. I would also appreciate if QGIS would not
crash in this situation. Can you please provide a bug report?
Thanks,
Andreas
On 2016-05-23 14:30, Lauri Kajan wrote:
> Hi all,
> When creating a new relation between two layers in project settings I accidentally pressed enter after giving just a name of the relation. QGIS crashed and I got the minidump window.
> Can you confirm?
> I think the OK button should be disabled until all needed parameters are given.
> I filed a bug http://hub.qgis.org/issues/14869
> Thanks,
> Lauri
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160523/9a027547/attachment.html>
