[Qgis-developer] crash when adding relation with incomplete parameters
Matthias Kuhn
matthias at opengis.ch
Wed May 25 07:29:27 PDT 2016
Implemented the solution with disabling the ok button until all required
fields are there.
Can you check and give a feedback?
If it's ok, I'll backport to 2.14
Best
Matthias
On 23/05/16 14:40, Neumann, Andreas wrote:
> Hi Lauri,
> I had the same just recently. I would also appreciate if QGIS would
> not crash in this situation. Can you please provide a bug report?
> Thanks,
> Andreas
> On 2016-05-23 14:30, Lauri Kajan wrote:
>> Hi all,
>> When creating a new relation between two layers in project settings I
>> accidentally pressed enter after giving just a name of the relation.
>> QGIS crashed and I got the minidump window.
>> Can you confirm?
>> I think the OK button should be disabled until all needed parameters
>> are given.
>> I filed a bug http://hub.qgis.org/issues/14869
>> Thanks,
>> Lauri
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160525/3069066b/attachment.html>
