[Qgis-developer] ownership of QgsMessageBar(-items)
Nyall Dawson
nyall.dawson at gmail.com
Tue May 24 02:58:45 PDT 2016
On 24 May 2016 at 19:53, Marco Bernasocchi <marco at opengis.ch> wrote:
> Hi Richard, I alvays wanted to make a blog post out of this:
> https://github.com/mbernasocchi/pyqtExperiments/blob/master/qgis_thread_example.py
> I use message bars in theads there and never had issues.
> maybe it helps.
Marco - interesting stuff! Have you seen this PR yet?
https://github.com/qgis/QGIS/pull/3004
Looks like we share some common implementation details, so I'd be keen
to hear your thoughts on that proposed design.
Nyall
> ciao
> Marco
> On 24.05.2016 10:48, Richard Duivenvoorde wrote:
>> Busy with a plugin which retrieves (in separate threads) a lot of data
>> from 2 w*s services.
>> I thought to use the QgsMessageBar to show progress of the (two)
>> download processes, but stumbled on (I think) a problem:
>> - from api docs: https://qgis.org/api/classQgsMessageBar.html#details
>> The message bar will take ownership of the item...
>> My problem now is that (I think) my progressbars (which were place in a
>> QgsMessageBar-item-widget) are sometimes deleted although I still want
>> to use them...
>> For example: an user can click the little 'x' button in the messagebar
>> to clean up all messages.
>> Or a python dev can call 'clean all widgets'.
>> BUT at that moment a progressbar part of a messagebaritem is (at least
>> in cpp world) apparently deleted.
>> Meaning, if (in the python world) I set a progress value on it, I get a
>> nice clean segmentation fault....
>> I managed to work around this by NOT putting the progress bars in the
>> messagebar (but put small ones in the plugin toolbar), but as several
>> examples flow around on Google, I thought to speak out.
>> Should we just not let people do this?
>> Or was I using the messagebar for things I was not supposed to use if for?
>> Or should we make an option to add a 'special' widget to the messagebar,
>> which is NOT removed using clearWidgets() (either via Python or via
>> x-button)?
>> Regards,
>> Richard
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Marco Bernasocchi
> OPENGIS.ch - berna.io - 27summits.ch
