[Qgis-developer] ownership of QgsMessageBar(-items)
Marco Bernasocchi
marco at opengis.ch
Tue May 24 03:06:59 PDT 2016
I'll be in girona from Thursday, let's have a look there.
see ya
ciao
On 24.05.2016 11:58, Nyall Dawson wrote:
> On 24 May 2016 at 19:53, Marco Bernasocchi <marco at opengis.ch> wrote:
>> Hi Richard, I alvays wanted to make a blog post out of this:
>> https://github.com/mbernasocchi/pyqtExperiments/blob/master/qgis_thread_example.py
>> I use message bars in theads there and never had issues.
>> maybe it helps.
> Marco - interesting stuff! Have you seen this PR yet?
> https://github.com/qgis/QGIS/pull/3004
> Looks like we share some common implementation details, so I'd be keen
> to hear your thoughts on that proposed design.
> Nyall
>> ciao
>> Marco
>> On 24.05.2016 10:48, Richard Duivenvoorde wrote:
>>> Busy with a plugin which retrieves (in separate threads) a lot of data
>>> from 2 w*s services.
>>> I thought to use the QgsMessageBar to show progress of the (two)
>>> download processes, but stumbled on (I think) a problem:
>>> - from api docs: https://qgis.org/api/classQgsMessageBar.html#details
>>> The message bar will take ownership of the item...
>>> My problem now is that (I think) my progressbars (which were place in a
>>> QgsMessageBar-item-widget) are sometimes deleted although I still want
>>> to use them...
>>> For example: an user can click the little 'x' button in the messagebar
>>> to clean up all messages.
>>> Or a python dev can call 'clean all widgets'.
>>> BUT at that moment a progressbar part of a messagebaritem is (at least
>>> in cpp world) apparently deleted.
>>> Meaning, if (in the python world) I set a progress value on it, I get a
>>> nice clean segmentation fault....
>>> I managed to work around this by NOT putting the progress bars in the
>>> messagebar (but put small ones in the plugin toolbar), but as several
>>> examples flow around on Google, I thought to speak out.
>>> Should we just not let people do this?
>>> Or was I using the messagebar for things I was not supposed to use if for?
>>> Or should we make an option to add a 'special' widget to the messagebar,
>>> which is NOT removed using clearWidgets() (either via Python or via
>>> x-button)?
>>> Regards,
>>> Richard
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Marco Bernasocchi
>> OPENGIS.ch - berna.io - 27summits.ch
Marco Bernasocchi
