[Qgis-developer] [Processing][Rscript] Use Extent Parameter
Alexander Bruy alexander.bruy at gmail.com
Tue May 24 06:53:08 PDT 2016
Hi René-Luc,
extent and some other parameters/outputs currently are not available
in modeler and scripts. I plan to add support for missed params/outputs
at hackfest.
2016-05-24 16:40 GMT+03:00 René-Luc Dhont <rldhont at gmail.com>:
> Hi devs,
> Has someone already created a Rscript for processing which use an extent in
> input parameters ?
> By reading the code, I understand that extent parameter is not set in the
> RScript.
> In the method 'getImportCommands' of the 'RAlgorithm' class, ParameterExtent
> is never transform to an R command.
> Can someone confirm it ?
> How to pass translate ParameterExtent to RScript ?
> The getImportCommands code:
>     def getImportCommands(self):
>         commands = []
>         # Just use main mirror
> commands.append('options("repos"="http://cran.at.r-project.org/")')
>         # Try to install packages if needed
>         if isWindows():
>             commands.append('.libPaths(\"' +
> unicode(RUtils.RLibs()).replace('\\', '/') + '\")')
>         packages = RUtils.getRequiredPackages(self.script)
>         packages.extend(['rgdal', 'raster'])
>         for p in packages:
>             commands.append('tryCatch(find.package("' + p
>                             + '"), error=function(e) install.packages("' + p
>                             + '", dependencies=TRUE))')
>         commands.append('library("raster")')
>         commands.append('library("rgdal")')
>         for param in self.parameters:
>             if isinstance(param, ParameterRaster):
>                 value = param.value
>                 value = value.replace('\\', '/')
>                 if self.passFileNames:
>                     commands.append(param.name + ' = "' + value + '"')
>                 elif self.useRasterPackage:
>                     commands.append(param.name + ' = ' + 'brick("' + value
>                 else:
>                     commands.append(param.name + ' = ' + 'readGDAL("' +
> value
>             if isinstance(param, ParameterVector):
>                 value = param.getSafeExportedLayer()
>                 filename = os.path.basename(value)
>                 filename = filename[:-4]
>                 folder = os.path.dirname(value)
>                 else:
>                     commands.append(param.name + ' = readOGR("' + folder
>                                     + '",layer="' + filename + '")')
>             if isinstance(param, ParameterTable):
>                 value = param.value
>                 if not value.lower().endswith('csv'):
>                     raise GeoAlgorithmExecutionException(
>                         'Unsupported input file format.\n' + value)
>                 else:
>                     commands.append(param.name + ' <- read.csv("' + value
>                                     + '", head=TRUE, sep=",")')
>             elif isinstance(param, (ParameterTableField, ParameterString,
>                                     ParameterFile)):
>                 commands.append(param.name + '="' + param.value + '"')
>             elif isinstance(param, (ParameterNumber, ParameterSelection)):
>                 commands.append(param.name + '=' + unicode(param.value))
>             elif isinstance(param, ParameterBoolean):
>                 if param.value:
>                     commands.append(param.name + '=TRUE')
>                 else:
>                     commands.append(param.name + '=FALSE')
>             elif isinstance(param, ParameterMultipleInput):
>                 iLayer = 0
>                 if param.datatype == ParameterMultipleInput.TYPE_RASTER:
>                     layers = param.value.split(';')
>                     for layer in layers:
>                         layer = layer.replace('\\', '/')
>                             commands.append('tempvar' + unicode(iLayer) + '
>                                             + layer + '"')
>                                             + 'brick("' + layer + '")')
>                         else:
>                                             + 'readGDAL("' + layer + '")')
>                         iLayer += 1
>                 else:
>                     exported = param.getSafeExportedLayers()
>                     layers = exported.split(';')
>                         if not layer.lower().endswith('shp') \
>                            and not self.passFileNames:
>                                 'Unsupported input file format.\n' + layer)
>                         filename = os.path.basename(layer)
>                                             + layer + '"')
>                         else:
>                                             + 'readOGR("' + layer +
> '",layer="'
>                                             + filename + '")')
>                         iLayer += 1
>                 s = ''
>                 s += param.name
>                 s += ' = c('
>                 iLayer = 0
>                     if iLayer != 0:
>                         s += ','
>                     s += 'tempvar' + unicode(iLayer)
>                     iLayer += 1
>                 s += ')\n'
>                 commands.append(s)
>         if self.showPlots:
>             htmlfilename = self.getOutputValue(RAlgorithm.RPLOTS)
>             self.plotsFilename = htmlfilename + '.png'
>             self.plotsFilename = self.plotsFilename.replace('\\', '/')
>             commands.append('png("' + self.plotsFilename + '")')
>         return commands
> René-Luc
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
