[Qgis-developer] [Processing][Rscript] Use Extent Parameter
René-Luc Dhont
rldhont at gmail.com
Tue May 24 07:04:26 PDT 2016
Hi Alexander,
I have created a pull request https://github.com/qgis/QGIS/pull/3097
Regards,
Le 24/05/2016 15:53, Alexander Bruy a écrit :
> Hi René-Luc,
> extent and some other parameters/outputs currently are not available
> in modeler and scripts. I plan to add support for missed params/outputs
> at hackfest.
> 2016-05-24 16:40 GMT+03:00 René-Luc Dhont <rldhont at gmail.com>:
>> Hi devs,
>> Has someone already created a Rscript for processing which use an extent in
>> input parameters ?
>> By reading the code, I understand that extent parameter is not set in the
>> RScript.
>> In the method 'getImportCommands' of the 'RAlgorithm' class, ParameterExtent
>> is never transform to an R command.
>> Can someone confirm it ?
>> How to pass translate ParameterExtent to RScript ?
>> The getImportCommands code:
>> def getImportCommands(self):
>> commands = []
>> # Just use main mirror
>> commands.append('options("repos"="http://cran.at.r-project.org/")')
>> # Try to install packages if needed
>> if isWindows():
>> commands.append('.libPaths(\"' +
>> unicode(RUtils.RLibs()).replace('\\', '/') + '\")')
>> packages = RUtils.getRequiredPackages(self.script)
>> packages.extend(['rgdal', 'raster'])
>> for p in packages:
>> commands.append('tryCatch(find.package("' + p
>> + '"), error=function(e) install.packages("' + p
>> + '", dependencies=TRUE))')
>> commands.append('library("raster")')
>> commands.append('library("rgdal")')
>> for param in self.parameters:
>> if isinstance(param, ParameterRaster):
>> value = param.value
>> value = value.replace('\\', '/')
>> if self.passFileNames:
>> commands.append(param.name + ' = "' + value + '"')
>> elif self.useRasterPackage:
>> commands.append(param.name + ' = ' + 'brick("' + value
>> else:
>> commands.append(param.name + ' = ' + 'readGDAL("' +
>> value
>> if isinstance(param, ParameterVector):
>> value = param.getSafeExportedLayer()
>> filename = os.path.basename(value)
>> filename = filename[:-4]
>> folder = os.path.dirname(value)
>> else:
>> commands.append(param.name + ' = readOGR("' + folder
>> + '",layer="' + filename + '")')
>> if isinstance(param, ParameterTable):
>> value = param.value
>> if not value.lower().endswith('csv'):
>> raise GeoAlgorithmExecutionException(
>> 'Unsupported input file format.\n' + value)
>> else:
>> commands.append(param.name + ' <- read.csv("' + value
>> + '", head=TRUE, sep=",")')
>> elif isinstance(param, (ParameterTableField, ParameterString,
>> ParameterFile)):
>> commands.append(param.name + '="' + param.value + '"')
>> elif isinstance(param, (ParameterNumber, ParameterSelection)):
>> commands.append(param.name + '=' + unicode(param.value))
>> elif isinstance(param, ParameterBoolean):
>> if param.value:
>> commands.append(param.name + '=TRUE')
>> else:
>> commands.append(param.name + '=FALSE')
>> elif isinstance(param, ParameterMultipleInput):
>> iLayer = 0
>> if param.datatype == ParameterMultipleInput.TYPE_RASTER:
>> layers = param.value.split(';')
>> for layer in layers:
>> layer = layer.replace('\\', '/')
>> commands.append('tempvar' + unicode(iLayer) + '
>> + layer + '"')
>> + 'brick("' + layer + '")')
>> else:
>> + 'readGDAL("' + layer + '")')
>> iLayer += 1
>> else:
>> exported = param.getSafeExportedLayers()
>> layers = exported.split(';')
>> if not layer.lower().endswith('shp') \
>> and not self.passFileNames:
>> 'Unsupported input file format.\n' + layer)
>> filename = os.path.basename(layer)
>> + layer + '"')
>> else:
>> + 'readOGR("' + layer +
>> '",layer="'
>> + filename + '")')
>> iLayer += 1
>> s = ''
>> s += param.name
>> s += ' = c('
>> iLayer = 0
>> if iLayer != 0:
>> s += ','
>> s += 'tempvar' + unicode(iLayer)
>> iLayer += 1
>> s += ')\n'
>> commands.append(s)
>> if self.showPlots:
>> htmlfilename = self.getOutputValue(RAlgorithm.RPLOTS)
>> self.plotsFilename = htmlfilename + '.png'
>> self.plotsFilename = self.plotsFilename.replace('\\', '/')
>> commands.append('png("' + self.plotsFilename + '")')
>> return commands
>> René-Luc
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
