[Qgis-developer] QGIS compiling with Qt5 and Python3 on Debian
Paolo Cavallini
cavallini at faunalia.it
Fri May 27 00:40:07 PDT 2016
Il 26/05/2016 19:43, Vincent Picavet (ml) ha scritto:
> Hello,
> On 26/05/2016 19:31, Paolo Cavallini wrote:
>> Hi all,
>> I was finally able to compile, install, and run (thanks Matthias!) the
>> above on a clean virtual machine. I've added the list of necessary
>> packages to the INSTALL doc in master. Others please try and report.
>> In case someone would need it, I can upload the VM somewhere.
> Good news !
> Do you have a Vagrant file we could use (and publish) to generate the VM
> directly ?
Forgot to tell:
cmake -DENABLE_QT5=ON -DPORT_PLUGINS=ON
make
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
