[Qgis-developer] QGIS compiling with Qt5 and Python3 on Debian
Matthias Kuhn
matthias at opengis.ch
Sun May 29 02:08:00 PDT 2016
Hi Médéric,
This is very well possible, I always run from the build directory, so I
didn't check the install instructions and the PORT_PLUGINS functionality
has been introduced relatively recently and not widely been tested.
Matthias
On 29/05/16 10:19, Médéric Ribreux wrote:
> Hello devs,
> I am developping for QGIS under Debian Stretch and I have tested the
> qt5/Python3 port of QGIS.
> But I am facing a problem with python3 plugin ports:
> * I use PORT_PLUGINS CMake parameter.
> * With this parameter, plugins are "auto-ported" to Python3 with 2to3
> tool.
> * The result of the "port" is made in the output directory of the
> build directory (output/python/plugins).
> * But it seems that `make install` takes directly files from the code
> directory instead of the build directory.
> * This leads to install python2 version of the plugins instead of
> python3 version and plugins just crashes at QGIS opening.
> I am a CMake newbie so I would like to check if I have not forgotten
> anything.
> Do you have the same behavior ?
> Cheers,
> PS: I can't find something that installs/copies python3 plugins files
> in install prefix directory in python/plugins/CMakeLists.txt...
> Le 2016-05-27 17:01, Sebastiaan Couwenberg a écrit :
>> On 05/27/2016 04:57 PM, Yves Jacolin wrote:
>>> On Friday, May 27, 2016 10:49:55 Sebastiaan Couwenberg wrote:
>>>> On 05/27/2016 07:15 AM, Paolo Cavallini wrote:
>>>>> apt-egt install git build-essential cmake flex bison pyqt5-dev
>>>> s/apt-egt/apt-get/, the documentation has this typo too.
>>> Any link? I can't find it :)
>> It was in the initial commit:
>> https://github.com/qgis/QGIS/commit/36161fc05dd869f7da9ccaad843105e71b9a5af7#diff-6a755e7d228a2b491321dbae0a7a248bR347
>> But has since been fixed:
>> https://github.com/qgis/QGIS/commit/84c0241776cdbc98e5ee27d5af98d7605badcec4#diff-6a755e7d228a2b491321dbae0a7a248bL348
>> Kind Regards,
>> Bas
